Rear end ?
Old Apr 12, 2010 | 12:34 PM
Jim Hunt's Avatar
Jim Hunt
Rear end ?
How do I find out what rear end gearing I have?
Thanks in advance.
Jim
Old Apr 12, 2010 | 12:48 PM
Midwest Dually's Avatar
Midwest Dually
Gearsm gears and more gears!
Dave on here just answered this question for me a few days ago.. Here you go:
Bottom line on the tag will start with .10, .73, or .55 if it is an open axle.
Bottom line will start with L10, L73 or L55 if it is limited slip.
The 10 number will be a 4.10 ratio axle
The 73 number will be a 3.73 ratio axle
The 55 number will be a 3.55 ratio axle
The next three numbers, either 10 2 or 10 5 will indicate 10.25" ring gear or 10.5" ring gear.
All trucks 97 and before should be 10.25" ring gear with 6.5" x 8 bolt pattern on the hubs.
99 and newer trucks should have the 10.5" ring gear with 170 mm x 8 bolt pattern on the hubs.
The ring gear and pinion should be interchangable, but pay attention to the pinion shaft length.
There were two styles, long and short shaft, if they are different you need to swap the yoke as well.
Old Apr 12, 2010 | 07:43 PM
Jim Hunt's Avatar
Jim Hunt
Thanks a bunch that answered it perfectly
Pebs99
Jul 19, 2011 09:04 PM
Jim Hunt
24
Jun 19, 2010 09:47 PM
JimG1098
Feb 28, 2010 04:35 PM
raerjim
21
Dec 11, 2006 06:13 AM
jim907
Jul 13, 2001 06:08 PM
