Sponsored by: Auxito
rear grind while turning from stop
Old Apr 12, 2010 | 08:14 AM
wolfgang031691's Avatar
wolfgang031691
I have a 2002 F150 XLT FX4. It doesn't happen every time but it only happens when turning from a stop.
It happens turning both left and right.
I get a very quick grind sound from my rear end. I am thinking a bearing is going bad on my rear axle.
I've read when a rear-diff fluid change can help this out. I will try that.
If that doesn't work, can I fix this (IE how difficult is this)? Or am I better off taking it to the dealer?
Old Apr 12, 2010 | 06:12 PM
steve(ill)'s Avatar
steve(ill)
the noise is sthe limit slip cluthc chattering. when you turn a corner, the two tires have to turn at different speeds. the cluth slips. in a straight line, it dont do it... You need to go to Auto Zone and get a 7 oz bottle of friction modifier and add to the oil.. if your gear lube is original or old, you might want to change it out also. Use 75 w 140 synthetic.. takes 2 quarts i think,,, plus the friction modifier.
Old Apr 14, 2010 | 08:11 PM
Trevor1's Avatar
Trevor1
3 quarts of royal purple 75w140 would be best
Old Apr 14, 2010 | 09:43 PM
jimmy warren's Avatar
jimmy warren
my 98 f150 4x4 did the same thing when I first got it. it had the tires and wheels changed from 17's to 16's so I put the 17's back on it and it stopped
Old Apr 14, 2010 | 09:46 PM
rsylvstr's Avatar
rsylvstr
it's the clutch packs. i've tried RP, Amsoil, SynPower all with and without friction modifiers....no luck. will have replaced one of these days.
bmgnitro
1997 - 2003 F150
Jan 13, 2011 04:34 PM
HadleyL
Jan 3, 2011 07:51 PM
RoushFan00
2004 - 2008 F150
Dec 13, 2010 10:05 PM
Deleon
Jun 3, 2005 04:46 PM
