rear end leak
Old Apr 11, 2010 | 12:46 PM
4x4cody's Avatar
4x4cody
rear end leak
truck was fine the other day!
drove it yesterday evening not even a block and parked it! it was fine..
ive been trying to fix all the leaks and i did till this morning a walked out and noticed a puddle.. not good i suppose..
heres pics of my rear end ... look closely and you'll see
help me out! i need to get it fixed before something goes wrong..
Old Apr 11, 2010 | 01:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Pinion Seal, relatively easy to replace.
Drop the drive shaft, remove the u-joint yoke and remove old the seal.
Take the new seal, apply a thin coat of grease on the seal lip and a thin coat of sealer on the OD of the seal and install.
Check the yoke for wear or damage (nicks, scratches, etc) replace if needed (Bronco Graveyard has them).
Put some sealer on the splines of the pinion and yoke. Reinstall the yoke and put the nut on. Tighten the nut. DON'T overtighten the nut and absolutley DO NOT use an impact to tighten. If you do, this will change the pinion bearing preload and to reset it you will have to change the crush sleeve inside.
Then reinstall the drive shaft.
Check the oil level, add if needed.
Done
Old Apr 11, 2010 | 01:09 PM
4x4cody's Avatar
4x4cody
Great...Thanks...
looks like i'll be taking the school bus to school tomorrow then..ugh haha
Old Apr 12, 2010 | 10:20 PM
4x4cody's Avatar
4x4cody
bought a new seal.. a big 5 dollars..
looking forward to installing it this weekend.. haha i wish it would do it by itself over night! hehe
Old Apr 14, 2010 | 11:13 AM
RacerCoast's Avatar
RacerCoast
Unless you've got a nice impact wrench, be sure to eat your Wheaties before you try to remove the pinion nut!!!
Old Apr 14, 2010 | 11:31 AM
bkohne1's Avatar
bkohne1
I had to use heat and a 3/4 impact to get mine off. 1/2 impact just wouldnt cut it.
YellowSled
Sep 20, 2024 01:55 PM
Wyatt66f100
33
May 30, 2011 09:58 PM
Snowking
Aug 6, 2009 08:16 PM
Snowking
30
Jun 20, 2009 12:30 AM
Snowking
13
Jun 15, 2009 08:29 AM
