Tire pressure sensor fault
Old Apr 11, 2010 | 08:02 AM
026TB4U's Avatar
026TB4U
I'm receiving a tire pressure sensor fault on startup. Is this something I can fix myself? And if so, how?
How can I troubleshoot and can it be replaced without removing the tire?
Thanks in advance.
Old Apr 11, 2010 | 01:46 PM
alloro's Avatar
alloro
Unless you have a tire changer machine there isn't anything you can do. The sensor is at the base of the valve stem inside the tire.
Old Apr 11, 2010 | 08:08 PM
mtondreo's Avatar
mtondreo
You can try re-programming them first (search for the instructions, it was posted on here before, but I can dig them up if needed). This fixed mine for a bit (and will tell you if one is bad). Unfortunately I have one that is bad now - so waiting until a tire change and gonna pick some up off ebay. I knew which one it was - but that was two rotations ago, so know no telling now. Thanks, Mike
Old Apr 12, 2010 | 07:53 AM
026TB4U's Avatar
026TB4U
I did read about reprogramming it but wasn't sure if that would tell me which was bad. I'll give that a try. Can a speaker magnet be used?
If I do have a bad one, will a tire place change it out if you ask them to? I will be needing tires soon.
Anyone have a part number and a good (cheap) source?
Thanks.
Old Apr 12, 2010 | 08:06 AM
silly34's Avatar
silly34
Had this error appear, just reset it and it didn't error again. Sign of things to come?
Old Apr 12, 2010 | 08:07 PM
mtondreo's Avatar
mtondreo
yes you can use a speaker. Not sure how strong the magnet has to be. I used a 10" subwoofer I had laying around and one of them was giving me issues during the programming. That is the one that went bad. Most tire stores do not appear to have them in stock - you are better off buying them on your own. Hope this helps, Mike.
Old Dec 19, 2010 | 06:05 AM
026TB4U's Avatar
026TB4U
I finally got around to trying to fix this with no luck.
I purchased a new sensor and took it to Costco where they replaced it while mounting my tires. They ended up putting that wheel in the rear and now when I try to reprogram the sensors with a magnet, I am getting a bad reading on the first one (front driver's side).
So I either had another bad sensor that came from the rear (just me luck) or something else is wrong. I am going to try again on the next tire rotation. Any other ideas?
Thanks.
Old Dec 19, 2010 | 10:05 AM
daytomann's Avatar
daytomann
I've searched and csant seem to find the instructions...if you can point them out, that would be great.
Thanks!
I've got the same prob on my 03 EB.
Old Dec 19, 2010 | 10:28 AM
026TB4U's Avatar
026TB4U
Thanks!
Look at post #2
https://www.ford-trucks.com/forums/5...sors-tpms.html
Maybe you'll have better luck.
TLWright
2015 - 2020 F150
Mar 6, 2020 07:06 PM
bigfishford
75
Oct 11, 2017 04:48 PM
Ford091214
Nov 30, 2016 08:25 PM
forzas
Mar 6, 2016 04:29 PM
Taboo
Jul 11, 2006 01:55 PM
