Sponsored by: Real Truck
more tranny problems
Old Apr 15, 2010 | 02:31 PM
Fishin76's Avatar
Fishin76
Thanks for verifiying that fact, Mark..
Marc D.
Old Apr 15, 2010 | 02:58 PM
Boost240sx's Avatar
Boost240sx
Now that I remember when the truck actually shifted past 2nd 4 low did have all gears.
Old Apr 16, 2010 | 07:05 AM
Boost240sx's Avatar
Boost240sx
So I got Solenoid 2-3 failure for the code. The Ford computer said possible cause is Solenoid B failure or Solenoid C failure or mechanical failure. Getting a solenoid pack today and got my fingers crossed it is just solenoid failure and not mechanical failure.
Old Apr 16, 2010 | 07:43 AM
bubbasz1's Avatar
bubbasz1
If there is a lot of garbage in the trans pan when you open it up be wary. Could be you gernaded something and a bit of junk got into the solenoid pack. Had that happen to me. I rebuilt the trans before I replaced the solenoid pack, but it caused me a lot of grief after the rebuild>>until I replaced the solenoid pack.
Old Apr 16, 2010 | 02:53 PM
Boost240sx's Avatar
Boost240sx
When I drained the pan from replacing the seal, the fluid was clean and there were no chunks of metal around the magnet or in the bottom of the pan.
Old Apr 21, 2010 | 06:12 AM
Boost240sx's Avatar
Boost240sx
Alright well... replaced the shift solenoid and still no second gear. Is there anything above the solenoid pack the could my problem or am I looking at getting a rebuild? Thanks for any help, I'm tired of doing this
Old Apr 21, 2010 | 06:29 AM
bubbasz1's Avatar
bubbasz1
You can check the harness by unplugging it at both ends and checking it with a meter and that would rule out the harness. Other than that you maybe need a little help from our tranny expert, it's kind of sounding like a rebuild though.
Old Apr 21, 2010 | 09:54 AM
Boost240sx's Avatar
Boost240sx
I was starting to consider the doing that with the harness, does that harness end at another plug before it joins the engine harness (haven't looked yet).
I was hoping Mark might chime in... tried calling BTS but they're some tough cookies to get a hold of.
Old Apr 21, 2010 | 10:39 AM
bubbasz1's Avatar
bubbasz1
If I remember correctly it plugs into a connector on the drivers side near the middle to end of the exhaust manifold, above the frame.
Old Apr 21, 2010 | 09:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I thought I already chimed in...
Originally Posted by Mark Kovalsky
You need to check for codes with a compatible scan tool. You can also use it in data mode and see if the PCM is asking it to shift.
Old Apr 22, 2010 | 06:20 AM
Boost240sx's Avatar
Boost240sx
Sorry... I meant on the current situation. I posted the results of the scan a couple posts up, along with the replacement of the solenoid pack.
Old Apr 22, 2010 | 03:04 PM
Mark Kovalsky
So you verified that the PCM is commanding the shift?
Old Apr 23, 2010 | 10:27 AM
  #28
Boost240sx's Avatar
Boost240sx
Yes the PCM is commanding 3 and the trans isn't going there.
Old May 17, 2010 | 06:29 AM
  #29
Boost240sx's Avatar
Boost240sx
Since I could never find the solution to the problem posted I'll post what I found in case it helps someone in the future...
After rebuilding the transmission in my garage with the FactoryTech Monster Box kit as I was checking the valves in the main valve body before re-installing and I noticed the shift 2-3 valve not posistioned correctly. The spring was folded over at the slide and not returning the valve back into home posistion. After deburring the valve and bore it works like a champ. Trans works fine and was painfully and needlessly built to be bullet-proof for a stuck valve.
Tbow04
Jan 7, 2015 10:41 PM
posthumus86
1997 - 2003 F150
22
Dec 28, 2013 02:40 PM
Donna Judy-Creasman
1978 - 1996 Big Bronco
Mar 24, 2013 05:12 AM
MageBeowulf
17
Feb 10, 2012 03:49 PM
alabama madman
15
Jan 30, 2009 08:36 PM
