1978 - 1996 Big Bronco
Trans problems
Old Apr 8, 2010 | 11:02 AM
Eastla78bronco's Avatar
Eastla78bronco
Trans problems
Hey guys first of all I'm new here. I have a 78 bronco 460/c6/twnp205...
About 1 month ago my trans took a dump. So me and a buddyof mine rebuilt it. Now the trans is slipping and has a hising noise when ever u rev it...it doesn't mater if it's on PRND21...we did put in a shift kit...i checked the fluid and it's super burned..it is brown and smelled like eggs.. I thought it was the pump so I changed it, but that did not fix the isue..now could this be a bad torque converter or something whent bad in the valve body....I'm at a lost
Old Apr 8, 2010 | 01:40 PM
75F350's Avatar
75F350
Did it shift into all of the gears before the trans went south?
Did you use an old converter when you put this thing together?
You mentioned the pump? This was a new pump right? You did not re-use the old one?
Adjusted the bands correctly?
Any number of things can cause this, but if the fluid is that bad now, chances are great that you have cooked another transmission.
Old Apr 8, 2010 | 03:30 PM
Eastla78bronco
OMG...I really hope not. And yes the torque converter was new,and the pump was repuilt. It will go threw all the gears fine when it's cool but when it wormes up it starts sliping. But the hissing won't go away.
Old Apr 8, 2010 | 10:26 PM
f100beatertruck's Avatar
f100beatertruck
I know very little about autos, but if it's hissing all the time it might be an internal leak or problem with the pump. Can you get video or audio so we can hear the hiss?
Old Apr 8, 2010 | 11:24 PM
Eastla78bronco
ill try to get a vid tomorow...ill get my brotheres camera..
i already tryied changing the pump
ManfredVonRichtofen
Offroad & 4x4
47
Feb 1, 2013 05:56 PM
Grant J
Jun 1, 2011 08:10 PM
97REDPSD
Apr 18, 2007 02:38 PM
tmrider
Jun 20, 2004 09:48 AM
boitnott
Nov 17, 2000 11:11 AM
