INJECTORS
Old Apr 7, 2010 | 09:09 PM
BIG J82's Avatar
BIG J82
INJECTORS
i have a 95 psd
whats the differance between my injectors and the injectors from a 2000
my buddy wrecked his truck and now i have the chance to buy his drive train for cheap
so basicly i wanna know whats involved in putting it all into my truck
Old Apr 7, 2010 | 10:01 PM
kupaa's Avatar
kupaa
95 were single shots and your SD is split shots someone will chime in who knows more then me.
Old Apr 7, 2010 | 11:53 PM
CSIPSD's Avatar
CSIPSD
You can run the AD's... Its a nice bump in power, but your also going to want to grab his HPOP...
Old Apr 8, 2010 | 01:36 AM
BIG J82's Avatar
BIG J82
wouldnt it be better just to put his whole motor in ??
Old Apr 8, 2010 | 02:12 AM
CSIPSD's Avatar
CSIPSD
No reason to... the OBS have a better fuel system minus the fuel pump, some would say a stronger block. You could keep the 2000 motor as a core.
Old Apr 8, 2010 | 02:14 AM
BIG J82's Avatar
BIG J82
so put the pump in and the injectors
what about the pcm and the turbo
Old Apr 8, 2010 | 02:36 AM
CSIPSD's Avatar
CSIPSD
OBS turbo is better suited for larger injectors, the 1.15 exhaust housing is perfect for the 140cc AD injectors...
The PCM will not work in your truck. You could swap the IDM, might not notice it, but it puts out a bit more voltage.
Old Apr 8, 2010 | 07:37 AM
Izzy351's Avatar
Izzy351
You can run single shot tuning on splits, but not split shot tuning on singles so your PCM will run them...
Old Apr 8, 2010 | 08:53 PM
BIG J82's Avatar
BIG J82
if i put the wire harness in from the 2000 the pcm would work
Old Apr 8, 2010 | 09:00 PM
Pocket's Avatar
Pocket
Don't bother. Better to just get a chip that is tuned for split shot injectors. That way you can actually take advantage of the available fuel above the levels of stock fueling.
So injectors and HPOP from the engine, and order a chip with some custom tunes on it to run it properly.
Old Apr 8, 2010 | 09:04 PM
BIG J82's Avatar
BIG J82
well my intentions were to get stage ones and a chip in the first place
then my buddy said i could get this one
i thought there were more usfull parts then there really is
so are the 140cc splits better then a 160cc single shot
whats the diff
Old Apr 8, 2010 | 09:32 PM
Pocket's Avatar
Pocket
whats the diff
160cc's will give you more fuel while using less oil than any split shots.
iduger
Jan 20, 2011 04:52 PM
lostmybeer
39
Nov 15, 2010 01:01 PM
ggirten
20
Oct 14, 2010 11:43 PM
Johnny Be Cool
Aug 22, 2010 07:06 PM
matt71
Oct 29, 2008 07:08 AM
