question
Old Apr 7, 2010 | 04:40 PM
ricg's Avatar
ricg
question
what will mercon v do to the transmission. Ford dealership sold me mercon v trans fluid and i have put about 10,000 miles on it since then. Could this be my problem??
Old Apr 7, 2010 | 05:01 PM
utjer's Avatar
utjer
This should not be your problem. Ford has come out and said this is what should be used now. There has been lots of talk on this in the last 2-3 months. However, I dont know if the two can be mixed together. So if it was topped off with mercron V and you had LV in there, I do not know what that would do.
Old Apr 7, 2010 | 05:10 PM
ricg's Avatar
ricg
WeLl I had mercon sp in it but was a few about 3 or 4 qts low so I went to ford and they sold me mercon v so now the trans is messed up who's? Fault or was that the cause?
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Mercon SP is being replaced by Mercon LV. It's my understanding the two can be intermixed. Mercon V is a totally different animal and I'd get it out ASAP if that is indeed what is in your torqshift.
Old Apr 7, 2010 | 05:12 PM
utjer's Avatar
utjer
I did not catch that. Also I would find out why you were that low. Do you see any visible leaks?
Old Apr 7, 2010 | 06:05 PM
bismic's Avatar
bismic
Mercon V in your torqshift tranny will cause problems. You will probably need to have some solenoids replaced.
Old Apr 7, 2010 | 06:38 PM
69cj's Avatar
69cj
I would recommend that you take it to a dealer, ASAP, equipt for a power flush and get everything out of it, replaced with SP or LV and then replace the external filter. Maybe you will be lucky who knows??
Old Apr 7, 2010 | 07:11 PM
cheezit's Avatar
cheezit
if thats all hell be lucky
Old Apr 7, 2010 | 08:16 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
MERCON V will kill the solenoids in a TorqShift, and that can kill the rest of the trans.
Old Apr 7, 2010 | 08:22 PM
cheezit's Avatar
cheezit
ok so a little bit better discription. thx.
Old Apr 7, 2010 | 10:09 PM
bismic's Avatar
bismic
Shouldn't you get a flashing tow/haul light before you do too much other damage?
Old Apr 8, 2010 | 06:29 AM
Mark Kovalsky
Maybe, maybe not.
Old Apr 8, 2010 | 07:12 AM
brob1969's Avatar
brob1969
Did they put in the tranny fluid or just sell it to you? Did you tell the guy at the parts counter what kind of vehicle you needed fluid for?
Old Apr 8, 2010 | 07:21 AM
DSMMH's Avatar
DSMMH
I guess my first ? is what is the transmission problem?
My next thought is running the tranny 3 to 4 quarts low, with the X3 extreme street tune is probably what caused your problem and not adding the Mercon V. That is 1/4th of the transmission fluid capacity.
Did adding the Mercon V help or eliminate the problem?
However, I would get it flushed and filled with LV and see if the problem goes away.
DSMMH
Old Apr 8, 2010 | 08:21 AM
bismic's Avatar
bismic
Maybe, maybe not.
I read many forums (as I know you do) and I just do not read of many Torqshift problems except a few scattered solenoid failures.
