does this look right?
Old Apr 8, 2010 | 12:06 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Best bet if you want to post pictures would be to open a photobucket account, upload the pics to it then paste them into your posts.
Register for free at Photobucket.com
Simple to use, and it's free to boot.
Old Apr 8, 2010 | 08:59 PM
tobacco farmer's Avatar
tobacco farmer
Ok heres some more info. I took the ficm to the tv shop and he repaired the trouble spot. so after installing it back in the truck I checked the volts everything looked good so I tryed starting it no luck only thing that changed was everytime it cranked over it blew black smoke out the tail pipe. As I was cranking it over the ficmmpwr droped down to 42 v. when the key on it stayed above 47.0.
The codes changed cyl. 2,3,5,8 did show low and high voltage now all the show is the low voltage code for the same injectors.
I know its the FICM bad, and I had the guy check the soldering points and he said the all looked fine they did to me also.
Does anyoes anyone have a ficm for sale thats repairable. Thnaks
copracr
29
Mar 5, 2013 08:49 PM
1bad04
Oct 13, 2011 08:30 PM
dothedew192
38
Feb 7, 2011 03:36 PM
tobacco farmer
Apr 2, 2010 09:37 AM
Justin03PSD
19
Sep 9, 2009 05:34 PM
