Engine sludge
Old Apr 6, 2010 | 11:26 AM
Nathan Plemons's Avatar
Nathan Plemons
Originally Posted by TriumphTune
. I know this is about the most non-scientific evidence there is but I have never seen my dipstick get so dirty so quickly. (I know, I know, Flame Away...)
Josh
Biggest problem with Fram is usually the anti-drainback valve not working properly. All the oil will drain back out of the filter so when you start the vehicle, the filter has to fill back up before oil is pumped through the rest of the engine.
Old Apr 6, 2010 | 11:50 AM
mud bros's Avatar
mud bros
Originally Posted by Jermafenser
Take it out and tear it down.
^thats the only "right" way.
additives can loosten chunks that will fall into the pan and block the oil pump screen.
i have seen it a few times.
once she is sludged up like that make plans for a tear down and regasket a rebuild is not always required just dont undo the crank or rods.
im sure every 400 could use a regasket i know mine sure does
Old Apr 6, 2010 | 01:31 PM
TriumphTune's Avatar
TriumphTune
I have heard about the Anti-drainback valves also. And apparently they also use glued paper endcaps to hold the pleats together.
I remember when Honda had Honeywell (Fram) start making some of their filters, people went ape. I don't blame them. You can tell which by the model number which was different. So everybody would buy the S2000 filter or figure out which dealers had stock of the other one. This is not to say that Honda didn't oversee the design and manufacture but still...
Josh
Old Apr 6, 2010 | 01:47 PM
berry1234's Avatar
berry1234
I agree, never use Scam I mean Fram.
Old Apr 6, 2010 | 02:00 PM
TriumphTune
Haaa, Good One!
Old Apr 6, 2010 | 08:00 PM
79FordBlake's Avatar
79FordBlake
Motorcraft FL-1A The only brand I will ever put on my truck. Possibly a wix.....
Old Apr 6, 2010 | 08:10 PM
79FordBlake
Probably needs main bearings also. Might as well check crank and order main and rod bearings.
I would be tempted to redo the whole shabang after goin that far. Just depends on your money situation. Never know you may end up with a 434 stroker, lol.
Old Apr 7, 2010 | 10:15 PM
TriumphTune
Definitely can't go wrong with Motorcraft or Wix or Napa Gold (Wix)
Old Apr 8, 2010 | 12:11 AM
73 fourxfour's Avatar
73 fourxfour
I agree with 79FordBlake about bearings and rebuild. I pulled the valve covers off of my 351m. It looked like coal around the rocker arms. Problem with sludge buildup like that is the oil doesn't drain back properly and the engine starves for oil. That is why I decided to pull the engine and I was glad I did because the bearings were toast. Rods and mains. Would not have been good for hauling a camper and towing a boat on a 100 degree day. At least check all the bearings. Good luck.
MGarner
Aug 17, 2020 12:11 PM
dgparsons2
18
Jan 26, 2009 07:36 PM
83maverickf-100
May 26, 2008 09:15 PM
smoke n tires
Mar 2, 2005 09:40 AM
BigShelby
Oil & Lubrication
17
Jan 23, 2004 05:54 PM
