Windshield wiper noise
Old Apr 5, 2010 | 07:31 AM
rlh68050's Avatar
rlh68050
Got into my Ex this morning to go to work and turned on the wipers to clear the windshield and there is a loud wining noise coming from the left side while they are running. Sounds like it could be the motor. They are working, but the noise doesn't sound good. Is this the motor itself or something else?
Old Apr 5, 2010 | 10:32 AM
fomoco6.8's Avatar
fomoco6.8
I have had the same problem crop up recently. It started about 2 weeks ago with just a slight gear noise and then a few days ago something seemed to snap. Wipers continue to work but now with a much louder growl. Should be easy to pinpoint once I get in there. I suspect a transmission bearing or possibly the motor itself. Will report whatever I find...
Mike
Old Apr 5, 2010 | 10:49 AM
rlh68050's Avatar
rlh68050
Mike
Mine started just this morning and is quite loud. Definitely coming from the drivers side where the motor is. Wipers do work just as you report. I would think that is in the motor gear case. When you buy a new motor it comes complete with the gears assembly ready to go. You just have to remove the transmission assembly to get at the motor. Let me know how you find.
Old Apr 6, 2010 | 08:59 AM
rlh68050's Avatar
rlh68050
Fixed it last night as rain was forecast for today and I needed to make sure the wipers wouldn't quit. It was the motor. Pretty easy to replace. Just remove the blades, cowling, and then finally the motor/linkage assembly. You can then remove the motor from the linkage (I reconnected the motor by itself ran it - that was the source of the noise). $55 at O'Reilly's for a new one, lifetime warranty.
Old Apr 6, 2010 | 12:43 PM
fomoco6.8's Avatar
fomoco6.8
Excellent! thanks for the heads up...doing mine tomorrow.
By the way, mine is also a 2001.
Mike
ArlyDude
Dec 14, 2014 09:32 PM
bigdan1979f-250
Dec 23, 2009 06:40 PM
Ford-Trucker84537
Jun 5, 2009 06:15 PM
bplumb
1997 - 2003 F150
Mar 15, 2004 07:24 PM
Wakeboarder141
1978 - 1996 Big Bronco
Oct 1, 2003 12:28 AM
