wrench light?????what does it mean???
Old Apr 5, 2010 | 10:01 PM
ford4x4956's Avatar
ford4x4956
the wrench light did not come one until 30 min after the reflash truck still runs the same as b4 the reflash, and the first thing i suspected was maybe the eot and ect were not within limits but i have a coolant filter and a 7 month old oil cooler i hope i dont need another oil cooler
Old Apr 5, 2010 | 10:06 PM
ford4x4956's Avatar
ford4x4956
wrench light comes one while normal driving and no hard start, and i have a full egr delete maybe its detecting low egr flow....i hope thats what it is
Old Apr 5, 2010 | 10:51 PM
tex25025's Avatar
tex25025
That could be possible especially since you haven't replaced your diablo with custom tunes yet(atleast going by your siggy). I did a bypass and I already had tunes that had the EGR turned off even before I did all my modifications, so I never had an experience with the wrench light with regard to EGR flow.
Old Apr 6, 2010 | 09:28 PM
98SurplusExpy's Avatar
98SurplusExpy
No EGR delete here ... but I have a less than 1K mile old EGR coller & Oil Cooler.
I don't get the light on short drives (less than 10 miles) ... but if I get on the highway for any amount of time it will come on.
Old Apr 6, 2010 | 09:30 PM
98SurplusExpy
Originally Posted by gearloose1
Can you tell me what month / year flash started to do this?
That way, I can make sure I don't flash again until the OBDII readers catch up with it.
TSB 09-24-3 is dated Novermber 20, 2009. I just got the flash a week ago & that's when the light started up.
Old Apr 7, 2010 | 12:49 AM
ford4x4956's Avatar
ford4x4956
mine comes on on long drives too...like 30mins and up
Old Apr 10, 2010 | 10:37 PM
98SurplusExpy
Got my stored "wrench light" code read at the Ford Dealer today ... as I suspected, it was the DTC P012F for the oil cooler efficiency.
So I say to the Tech ... "but you guys just changed my EGR & Oil Coolers less than a thousand miles ago". Tech says that in his experience, its probably a dirty oil temperture sending unit (3C3Z-10884-AA or Motorcraft SW-6052) ... he suggests cleaning it or replacing it. He said "its definitely not a plugged oil cooler".
Old Apr 11, 2010 | 01:41 PM
ford4x4956's Avatar
ford4x4956
yup i got the same issue, i replaced the oil cooler about 7 months ago and ive had a coolant filter ever since guess i try cleaning the sensor or just replacing if its not too expensive
Old May 12, 2010 | 09:19 AM
nylyon's Avatar
nylyon
Did you determine the cause of your issue? Really interested to know if replacing the temp sending unit helped with your issue?
Old May 12, 2010 | 08:41 PM
98SurplusExpy
Actually just picked up a new Temp Sending Unit today; should get it installed in the next few days. I'm also gonna get an Edge Insight monitor to get a visual on the Temp spread.
Light still comes on when I'm on a 30 mile or so steady highway drive.
I'll follow up with findings.
Old May 12, 2010 | 09:44 PM
cheezit's Avatar
cheezit
either eot/ect split. overboost, or low voltage. none of them are good codes.
Old May 13, 2010 | 07:57 AM
nylyon's Avatar
nylyon
Fantastic, I'm trying to figure out a similar problem Saga tale here and it seems very similar to yours. I'll wait on your results with the sensor before I go and get one too. Thanks.
Old May 13, 2010 | 03:02 PM
  #28
nylyon's Avatar
nylyon
Well, I went and did it anyway. Bought a new oil temperature sensor and put it in. Very simple job to do. No difference for me.
Old May 13, 2010 | 06:28 PM
  #29
cheezit's Avatar
cheezit
Ive never seen a bad ect/eot sensor.
Old May 13, 2010 | 06:36 PM
  #30
69cj's Avatar
69cj
ScanGauge ll $159.00 at autoZone will read ect/eot.
