Gauges Not Working
Old Apr 2, 2010 | 10:57 PM
OregonGuy1978's Avatar
OregonGuy1978
Gauges Not Working
Have an 85 150 with inline 6. Oil gauge, temp gauge don't work and fuel gauge only somewhat. Could a bad ground cause a problem? Or just a bunch of bad sensors?
Old Apr 3, 2010 | 01:34 AM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Few questions....
Have you checked the fuses?
Replace if needed. I'd check them with a meter if you have one. No often but sometimes they can look ok but still be blown.
Are there any other gauges that do work like voltmeter or tachometer?
When you say the fuel gauge works "somewhat" do you mean it always reads full, empty, or does it float?
Again if you have a meter you could test your circuits for power or resistance or check for open circuits (short in system)
Do the dash warning lights come on when you first turn the key to run? The battery light, check engine light, oil pres warning, and any other warning light should come on briefly when the key is turned to run position.
If no, check the harness that plugs into the back of the cluster.
Old Apr 3, 2010 | 10:46 AM
ri_truck_guy's Avatar
ri_truck_guy
One the back of the cluster there's a small silver colored box the bolts on to the cluster and connects to the printed circuit with what resembles a 9 volt battery connection. That silver colored box is the instrument voltage regulator. It controls provides steady voltage to the gauge circuits. It fails quite often. If all three gauges are not working, chances are that's your problem.
RadioControlGuy85
27
Feb 4, 2016 12:28 PM
clinte89
16
Mar 9, 2015 07:11 PM
ROBZ95XJ
Dec 28, 2013 08:36 AM
jdhudall
19
Oct 6, 2006 06:17 PM
sparky
Oct 16, 2001 08:16 PM
