oil pressure gauge bad?
oil pressure gauge has stop working. put a new sending unit on,that didnt work. checked the back side of the cluster and didnt see anything unplugged or out of place.
when you turn the key on it will go to the middle of the gauge as soon as the truck starts it goes straight to no pressure at all.
is this a bad gauge or wiring?
Take the wire off the sending unit.
Turn on the key.
While the gauge is viewed.
Short the wire to ground.
The needle should go from from no pressure to the center of the gauge when the wire is grounded.
If it does that then the wiring and the gauge are fine.
You would then have a bad sending unit or engine.
Turn on the key.
Turn on the key.
The needle should go from the center of the gauge to no pressure when the wire is grounded.
Turn on the key.
ok switching gears,
my voltage gauge is dancing around now. would it be a bad cluster?
my oil gauge doesnt work. my temp gauge some times goes up and down at times then stays in the middle, and now my voltage gauge is dancing around. also my fuel gauge doesnt work either. could it be a bad cluster? what controls the cluster?
As you can see I guessed wrong as I posted a photo for a 1985 truck.
Now I would go back to say it was is a bad body ground.
Turn on the key.
Turn on the key.
I had it right the on the first post and I talked myself out of that way and when back and changed it.
Thanks.
Note that the sender is an off & on switch.
When the oil pressure gets above 5-7psi the switch makes the circuit to ground.
Oil Pressure Gauge and Oil Pressure Switch
The Oil Pressure Switch controls the magnetic Oil Pressure Gauge's pointer position. The Oil Pressure Switch closes under normal engine operating conditions; the Oil Pressure Switch opens with the engine off and no oil pressure.
