Sponsored by: Real Truck
Door Key Pad doesnt work
Old Apr 2, 2010 | 04:32 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Might add the battery then try to use it. If not them program away. Mine is a lariat and has the same keypad. I was under the impression this was a 99-04 design and 05+ got wired units or the keypad was added as a dealer install after 05.
Old Apr 2, 2010 | 04:34 PM
Lubbockguy1979
I'd add that you have a master code on the key pad. You can add a second code as a vallet or for other people to use. The second code can be erased or changed later if needed.
Old Apr 3, 2010 | 09:43 PM
scottzj's Avatar
scottzj
Hangin 10 bra
Update.....it wasnt the battery. It was due to me adding key fobes and not adding the keypad back. However, I did find out you can only have 4 controllers total for your truck. Meaning, the keypad is considered one controller or fobe. So I just did 3 remotes and the key pad. So I am all good and works like a champ.
Old Nov 12, 2020 | 04:54 AM
Heath Poindexter's Avatar
Heath Poindexter
Keyless Entry on 2004 Super Duty dead
I wanted to share my experience from yesterday in trying to replace the battery in the keyless entry. First the top didn't come off easily at all, I went to a body shop and the friend helped me remove it from the door completely then worked to open it and that was a chore in itself! We spent an hour at least removing the remote cleaning the residue from paint to find no battery locally so I had to order one. The battery was a CR2335 3v that's not a common nickel battery that is used. So to sum it up plan on removing the remote if it doesn't pop off easily and reattach when done with two sided tape that body shop uses and believe me that stuff is sticky! Good luck!!
Old Nov 6, 2022 | 10:48 AM
Bruhaun's Avatar
Bruhaun
1st Gear
Key Pad Broke
2004 F250 super duty- Same problem as Heath, however, mine is trashed. Can’t find the correct replacement on line for the stick on style…. Still searching…. Any suggestions?
Moe Craig
Feb 12, 2018 02:33 PM
bill balsewice
Aug 10, 2017 02:36 PM
Michaelmx
Dec 6, 2016 08:18 PM
Super Duty 36
Mar 17, 2016 12:50 AM
zippinz
Aftermarket Products
Aug 5, 2002 08:56 AM
