Sponsored by: Real Truck
mind blown
Old Aug 10, 2017 | 09:09 AM
bill balsewice's Avatar
bill balsewice
Cool mind blown
hi all
I just did a simple front pad replacement, new pads and gave them a bleed. now it wont come out of park with key on. first key position, neutral, then start, as soon as it goes into park, wont come back out. air in lines? not sure. then windows wont work, what happened? done many brake jobs and never had this happen. please help
Old Aug 10, 2017 | 09:27 AM
seville009's Avatar
seville009
Just a stab in the dark, but check under your brake pedal to make sure that nothing is blocking the safety switch (ie: have to have the brake pressed to shift out of park)
Old Aug 10, 2017 | 09:34 AM
bill balsewice
I did because I replaced brake boost few months back and that was the hardest part and was doing same thing.
thank you
Old Aug 10, 2017 | 09:46 AM
alloro's Avatar
alloro
The new pads or bleeding has nothing to do with the brake interlock system. The interlock is electrical and the brakes are mechanical.
Old Aug 10, 2017 | 09:56 AM
bill balsewice
ty
that's why I cant figure it out.
thanks
Old Aug 10, 2017 | 10:01 AM
Mike1's Avatar
Mike1
Is there a fuse that may have gotten blown, did wires get pulled, maybe partially unplugged or did the switch get damaged. As always, 1st rule is to go back over what you did, if it was working before you fixed it.
Old Aug 10, 2017 | 10:22 AM
maticuno's Avatar
maticuno
Make sure the brake switch didn't get unplugged.
Old Aug 10, 2017 | 10:26 AM
bill balsewice
thank you to all!!!!!!
found it lol. slammed door coke can got caught smashed the little light in door and blew fuse.
again
thank you!!!!
Old Aug 10, 2017 | 01:21 PM
speakerfritz's Avatar
speakerfritz
not really sure...I had a mustang that had a broken wire on a switch near the brake pedal and it did exactly what you are discribing
I also had an expedition and a navigator that had 2 loose bolts under the dash that held part of the steering colum..and with those bolts loose...exactly what you describe.
maybe when you pumped up the brakes to bleed them you kicked off that sensor wire?
Old Aug 10, 2017 | 02:36 PM
Diamnd1's Avatar
Diamnd1
again
thank you!!!!
Drinkin on the job!!
BritishMiss
1983 - 2012 Ranger & B-Series
Aug 11, 2011 08:31 AM
syver
Feb 8, 2011 04:30 PM
briandrex
Nov 25, 2007 10:33 AM
Dwights
Jan 15, 2004 05:26 PM
bigdogsleeping
Oct 3, 2003 11:10 PM
