Sponsored by: Real Truck
Body swap
Old Nov 27, 2020 | 11:14 AM
Arthur VanOver's Avatar
Arthur VanOver
Body swap
Is it possible that a 2008 f350 crew cab fit on a 2002 f350 frame?
Old Nov 27, 2020 | 08:40 PM
6point0's Avatar
6point0
Are they both crew cabs? Both the same wheel base?
I know the boxes are the same, the cabs should have the same body mounts. As far as wiring and all that... I'm sure none of it will be a direct swap
Old Nov 28, 2020 | 06:25 AM
Dan V's Avatar
Dan V
The 08 cab will physically bolt to the frame. You are going to have to modify the firewall to accept the 02 pcm mount...where it sticks through the firewall. Then you will have to put the entire 02 dash in the 08....all the wiring form the 02 needs to go in to the 08 cab.....all of it.
Old Nov 28, 2020 | 08:26 AM
Firefighter 1406's Avatar
Firefighter 1406
Are you saying that all the wiring must swap?? 🤣
Old Nov 28, 2020 | 08:44 AM
Bugzilla46310's Avatar
Bugzilla46310
Search this site. It will have the dimensional information you need.
https://fordbbas.com/home
Old Nov 28, 2020 | 11:19 PM
Arthur VanOver
Thanks for info 👍
Old Nov 29, 2020 | 10:03 PM
RigCity's Avatar
RigCity
Will the dash drop right in or will there be modifications required to mount it?
Old Nov 30, 2020 | 07:37 AM
Dan V's Avatar
Dan V
Bolts right in
Old Nov 30, 2020 | 02:45 PM
99powerstrokedF250's Avatar
99powerstrokedF250
The cab didn't change much from '99-10, maybe further than that, I'm not sure. I do know the difference between an '03 and an '08 was primarily the front clip.
Old Nov 6, 2022 | 03:07 PM
Walt Collins's Avatar
Walt Collins
5th Gear
Does anyone know if i can do a full body swap from my 2004 f350 super duty regular cab to a 2005 ford f150 super crew body
Matthew Engelsen
May 3, 2022 02:20 PM
Shadekure666$lim
Feb 18, 2019 07:22 AM
Katrink
Jun 2, 2015 05:50 PM
Nsaan
Apr 4, 2013 05:07 PM
jchungerford
Sep 19, 2004 07:26 PM
