thermostat
Old Apr 1, 2010 | 03:28 PM
bearhugger's Avatar
bearhugger
thermostat
Think i need a new thermostat,the only one i can find local is 205 deg.Dealer said stock was 192 deg,do you think the 205 will be ok.
95 f350 cc std srw.
Jim
Old Apr 1, 2010 | 03:56 PM
JamesHajek's Avatar
JamesHajek
I think thats what i put in my truck when i replaced the stat.
Old Apr 1, 2010 | 04:18 PM
KonaGrown's Avatar
KonaGrown
Our trucks run alot more effecient with the 205* thermistat
Old Apr 1, 2010 | 06:36 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Out trucks run way better with the 205* thermostat. I know mine runs alot better.
Old Apr 1, 2010 | 07:36 PM
Tom S's Avatar
Tom S
There are two different thermostats depending on which water pump you have. You need to use the correct one to match your pump. They are long or short.
Old Apr 1, 2010 | 08:37 PM
Jim Hunt's Avatar
Jim Hunt
So how do we know what one we need to use long or short?
Old Apr 1, 2010 | 09:04 PM
bearhugger's Avatar
bearhugger
The 205 deg that i looked at was the short one.How do i know which one i have with out pulling mine first.
Old Apr 2, 2010 | 09:09 AM
Tom S's Avatar
Tom S
I not sure how to direct you as I suspect your waterpump has been replaced at some time. If you do some internet searching this issue has been written about many many times so you might find some help. I would just get both parts and return the wrong one if I was in your spot.
thermostat info
https://www.ford-trucks.com/forums/6...nightmare.html
International parts that fit 7.3L? - Diesel Forum - TheDieselStop.com
for a start
vtjvt
Jan 24, 2015 11:17 AM
obscurity
Jun 10, 2013 10:32 AM
hammer65
55
Sep 21, 2011 05:14 PM
PeeVee
13
Apr 26, 2008 11:02 PM
JimmieDee
Escape & Escape Hybrid
Jan 2, 2006 09:18 PM
