Fuel pressure questions please help!!!
Old Apr 1, 2010 | 11:11 AM
agg_bagg's Avatar
agg_bagg
Hey guys. I need some input on my trucks fuel pressure. My truck started losing power so I changed all the fuel filters. When I was putting it all back together I hooked up a fuel pressure gauge to the top test port on the fuel bowl. My truck runs pretty good again but these are the pressures I got
Idle: 60-62 psi
Calm driving: about 60 psi
WOT/under load: 52-55 psi
So now I am wondering I my fuel pump is going bad. Because I was always under the impression that the fuel pressure should hold steady under all conditions.
Any input you have would be great, Thanks
Jeron
Old Apr 1, 2010 | 11:19 AM
kupaa's Avatar
kupaa
That seems good i know when i installed my regulated return it said to keep the pressure around 50 psi.You might want to bring it down a little.I don't know if it's better to have it at 60 lbs.Some will chime in who knows more then me.
Old Apr 1, 2010 | 11:20 AM
bfife's Avatar
bfife
still plays with trucks
Jeron, they seem about normal. IIRC ford says anything above 50 is OK. I just drove up from GJ Colorado to SLC towing my house. I watched FP the whole way 52-54 at WOT, 58-60 idle. I think a RR and adjustable regulator will be on my list of future mods.
on a side note I'll be here all summer, maybe we can plan a G2G when it warms up.
Barney
Old Apr 1, 2010 | 11:38 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Your fuel pressure is fine. Ford considers normal operating pressure to be 51 psi +-4 psi, so if you aren't getting under 50 psi at WOT then I wouldn't worry about it at all.
Old Apr 1, 2010 | 04:33 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Hey Jeron, where did you connect your gauge
http://www.frybrid.com/forum/attachm...5&d=1260431751
top left port or bottom right
Old Apr 1, 2010 | 06:44 PM
danskool's Avatar
danskool
Go Bills !
Those are the same numbers mine was getting before i shimmed it.. Shimmed it every were between 45 to 70.. Never made one bit of difference how it ran. Been at 65psi since last summer.
Old Apr 1, 2010 | 06:51 PM
ron's power stroke's Avatar
ron's power stroke
you can run a stock pump with stock sticks down to 40 PSI and not loose anything..thats because you run out of oil first....
Old Apr 2, 2010 | 08:58 AM
01 EXCURSION MORRIS's Avatar
01 EXCURSION MORRIS
Subscribing
Old Apr 2, 2010 | 11:35 PM
agg_bagg's Avatar
agg_bagg
ok thanks guys that makes me feel alot better..... and Barney that would be great, i have only met one other FTE guy. i don't think to many people from utah are active on here. send me a pm with some info on when you will be here and how to get a hold of you and we will meet up sometime.
Old Apr 3, 2010 | 10:41 AM
guzzle92's Avatar
guzzle92
That is a good question but may not be relevant with a new fuel filter.
Just FYI, the port on the driver's side (top left) is unfiltered fuel pressure and the one on the passenger's side (bottom right) is filtered pressure.
A comparison of the two pressures would give you an idea of the need to change fuel filters but I don't know many that would want to go to the expense of installing two remote sensors and rigging up a switch to flip from one to the other.
Old Apr 3, 2010 | 12:25 PM
Izzy351's Avatar
Izzy351
I just watch the filtered side. If it starts dropping more than usual, time for a new filter. Once you know what it's doing with a new filter, you'll know when it's getting to be time to change it. My $0.02...
Old Apr 3, 2010 | 12:26 PM
John7894's Avatar
John7894
Guzzle, you could find a differential pressure switch and wire up an idiot light to it. Just thinking out loud since we're always thinking of stuff to modify or add...
Old Apr 3, 2010 | 04:02 PM
ChunderDownUnder
The reason I ask was I originally had mine filter side with a cheap under hood gauge. Set at 65psi with my RR. Then I put a electrical in cab gauge on the head side of the fuel bowl and was only getting 40 psi. Had to bump up the RR so pre filter read 80psi which gave me 65psi post filter.
Knucks
Oct 23, 2016 07:49 AM
1994F2507.3L
Oct 14, 2016 03:58 PM
Sandman94F150
2004 - 2008 F150
Aug 8, 2015 10:13 PM
barnbridge
Apr 12, 2013 02:57 PM
Scott6.0PSD
Oct 17, 2011 09:01 PM
