Engine Bump?
Old Mar 31, 2010 | 03:51 PM
arno's Avatar
arno
Engine Bump?
On the highway last night and noticed what seemd to be an occasional bump in the engine. Kinda reminded me of my 02 7.3 when the cam position sensor was going. Not as bad, but seemd to happen once and a while. So slight I almost suspected road bumps but figued I would ask here and see if this is happening to anyone else.
09 5.4 FX4
Old Apr 1, 2010 | 08:25 AM
stephen.osborne1's Avatar
stephen.osborne1
sounds like American infrastructure in bad need of repair (bumpy road).
Old Apr 2, 2010 | 12:17 PM
palominof150's Avatar
palominof150
Yes your truck is making the noise
Yes you are correct. Our 09 F150 almost stalled in rush hour after heavy stop and go traffic last night. It's currently at the dealer will add more after truck is returned to me.
09 5.4 FX4
Old Apr 2, 2010 | 12:37 PM
stephen.osborne1
no Check engine light? You could go to Auto Zone and have them read any codes that might be there... Also, you can try a vehicle health report... Check your owner's manual on how to do this.
Old Apr 2, 2010 | 12:45 PM
arno's Avatar
arno
Truck runs great otherwise, just seems for no reason, to miss once and awhile. The problem with codes, as usual, it will likely not throw a code unless the miss is actually happening.
Old Apr 2, 2010 | 01:27 PM
stephen.osborne1
Could be a bad COP... had one going bad on my 2000 that made it feels almost like the trans was slipping. Had the dealer do a stress test on the COPs and sure enough, one was missing under load. Didn't trigger the CEL but I think there was a code to be read by the dealer's scanner.
Old Apr 2, 2010 | 06:55 PM
tvsjr's Avatar
tvsjr
Unless you've plugged in with a Ford laptop and checked the codes, you have no way of knowing this. There are hundreds of codes logged all the time that don't illuminate the Check Engine Light.
If you're having an intermittent miss, chances are there's a code logged (unless you've disconnected the battery). If not, they can attach a datalogger that will record even more information until the problem occurs.
eswatcher86
1997 - 2003 F150
Feb 19, 2013 12:57 PM
Thomas Hutchins
1997 - 2003 F150
Dec 18, 2011 11:46 AM
togie
Jan 17, 2007 08:43 AM
dscott21
Nov 30, 2004 03:32 PM
Jakea
Aerostar
Sep 24, 2003 11:33 AM
