Sponsored by: Real Truck
HELP!!! weird sound.....
Old Nov 28, 2004 | 11:27 AM
dscott21's Avatar
dscott21
It justed started this morning. I have a 1999 POwerstorke SD. It seemd to happen more at the shift point but also it seems to be happening when i decelerate at high speeds. It almost sounds like a blow off valve or a belt slipping. IT seems to be coralated with the tranny. All my gauges are good, my fluid levels are fine. The noise really scares me. It sounds bad. Like a screching almost. Any help would be great. Any questions that I can answer thaT would help you I will do my best to answer. Thanks
dustin
Old Nov 28, 2004 | 12:47 PM
Pocket's Avatar
Pocket
I was riding with my parents the other day, and their 03 7.3L was doing that too. It's an insanely loud and high pitched screeching/whistling noise that happens during acceleration at higher rpm's (2500-3000 rpm). The noise can be duplicated while driving, or while in park and reving the engine. I tried listening under the hood, but it is so loud I can't tell where the noise is coming from. I'm talking ear piercing loud. They said that people look at them funny when it happens on the road, so others on the highway can hear it as well.
Any clues so I can help them?
Old Nov 28, 2004 | 01:27 PM
F2504x4's Avatar
F2504x4
try removing the acc. belt and spin each pulley by hand, you may have pulley or belt tensioner bearing going bad...
Old Nov 28, 2004 | 04:08 PM
dscott21's Avatar
dscott21
If it is bad
lets say it is a puley bearing or something of the sort is it bad to drive it? What could possible go bad?
Old Nov 28, 2004 | 04:16 PM
F2504x4's Avatar
F2504x4
you could blow a belt , and generaly it will happen at the worst time, like 2am in the middle of nowhere.., the pulley could break and fly off and damage the radiator etc.....generally the replacement parts cost is about $ 100 or less plus price of a new belt...which is recomened.
also check the alternator too it could be goin south on you too .
Old Nov 28, 2004 | 04:41 PM
dscott21's Avatar
dscott21
thank you very much for the info. I am new to the powerstroke world and I am trying to learn as much as I can. I like to do my own work if you know what I mean.
Old Nov 29, 2004 | 09:15 PM
dscott21's Avatar
dscott21
the sound continues
My mechanic friend told me that it could be and most likely is the torque converter. Does that sound right to anyone.
And how much can i get one for?
Old Nov 29, 2004 | 09:23 PM
F2504x4's Avatar
F2504x4
just curious, did you remove the belt and checked all pulleys? also while the belts off , start it and see if the noise persists...just a thought...
maybe some else here will chime in......with more info
Old Nov 29, 2004 | 09:34 PM
dscott21's Avatar
dscott21
didnt have a chance to do it yet will do it in the AM,
Old Nov 29, 2004 | 09:40 PM
bluemoose89's Avatar
bluemoose89
if i am not mistaken the oil pump is belt driven not a good idea to run it with no belt.
Old Nov 29, 2004 | 09:44 PM
F2504x4's Avatar
F2504x4
ahhh i think this would be a good time for me to zip it and sit back and learn.
could you give some more info on this....
Old Nov 29, 2004 | 10:50 PM
MyTonka's Avatar
MyTonka
5th Gear
I was under the impression the oil pumps in PSD's were gear driven.
Old Nov 30, 2004 | 07:01 AM
m350's Avatar
m350
I recall there is a vacum pump on the PSD's, my 95' PSD launched one, and I had some fun stopping it with a load on it of course., But not sure about a belt driven oil pump, other then the power steering, I thought it was gear driven also. Better find someone that know's for sure.
Old Nov 30, 2004 | 07:12 AM
Maxium4x4's Avatar
Maxium4x4
It is okay to remove the belt, and no the oil pump is not belt driven. Isolate the noise by removing the belt. If no noise check your idle pulley, air conditioner, if it is the vacume pump you will be finding out soon when you hit your brakes...........
Old Nov 30, 2004 | 01:59 PM
bluemoose89
well i didnt know for sure about the oil pump drive. i wish i new more about my psd. i learned alot about my dodge i had at one time. simply because i had to work on it all the time.
