Help, Dana 60 Gurus
Old Mar 30, 2010 | 04:16 PM
Big Ruth's Avatar
Big Ruth
Help, Dana 60 Gurus
Greetings Ford fans.
My 95 f250 has a Dana 60 from a 97 f350. I put warn premium hubs in and they appear to work but I have a question about a part I put back on.
The picture is below where I put a red square around the part in question. The 1 end has a 90 degree bend in it which I put in kind of coaxed it into a keyed part then it bent around. What does it do?
Also. With the hubs locked, the 4x4 works fine but when I take it OUT of 4x4 the front hubs seem to stay locked until I reverse - like with auto hubs.
Thanks for any input anyone has!
Keith
Old Mar 30, 2010 | 04:39 PM
fishforlife2007's Avatar
fishforlife2007
my understanding was that you needed a new spindle locknut kit for it. then you will just have the spindle locknut, the hublock assembly, locking ring, and the front cover part...
Old Mar 30, 2010 | 05:26 PM
Big Ruth's Avatar
Big Ruth
Thanks for the reply. I wish I could find an good tutorial for my exact application. I think that makes sense what you are saying but the pictured doesn't show the spindle lock nut kit. Unless that's further in.
Old Mar 31, 2010 | 09:50 PM
fishforlife2007
the picture that you have doesnt show the spindle lock nut kit since that is an exploded diagram of a 4wd, with auto hubs. if you look up one with the manual hubs then you will see what i am talking about when comparing the two.
this thread may help you out more..
https://www.ford-trucks.com/forums/8...e-hub-off.html
brian1080
Jun 8, 2014 01:52 PM
keith180
Mar 30, 2011 08:01 AM
blacklabel21
Jan 16, 2011 09:20 PM
johnsonacres
Jan 12, 2004 12:58 PM
