Dana 60 question
Old Jan 16, 2011 | 04:32 PM
blacklabel21's Avatar
blacklabel21
Dana 60 question
I have a 1978 ford f250 351m 4 speed 4x4 Well i want to put a arb locker in my front dana 60 axle. my question is what gear ratio is my front axle.What i do know it is a 30 spline becuase i put mm lock out hubs on it.
Old Jan 16, 2011 | 04:44 PM
CaptainIPSC's Avatar
CaptainIPSC
Most are 3.53/54:1 but you have to read the tag or better yet, pull the cover and count the teeth. You'll reuse your gears anyway, unless your wanting to change the ratio. In that case it doesn't matter. You're right about the spline count but that is on the outers. Mine has 35 spline at the locker.
Old Jan 16, 2011 | 04:49 PM
OrFordGuy's Avatar
OrFordGuy
first look at the front cover there should be a mall metal tag attached by a bolt...if theres not one lock the hubs, jack up one side, mark the pinion and housing in relation to each other, rotate tire one turn count pinion rotation multiply by 2...that'll get you close...then check availible gears ratios for your axle then you should be figuring it out...
Old Jan 16, 2011 | 05:57 PM
Talltruck's Avatar
Talltruck
If you pull the cover the ring gear will have the number of teeth scribed into it; i.e. a 4110 means 41 teeth on the ring gear and 10 on the pinion or a 4.10 ratio.
My Dana 60 front has 35 spline inner axles too for what it's worth.
Old Jan 16, 2011 | 06:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford ID axle tag: Located under one of the bolts that retains the inspection cover to the housing...do not be surprised if it's missing.
Dana 60 ID axle tag:The 2" x 1/2" metal tag is bolted to the housing adjacent to the inspection cover to the left (rear axle) or right (front axle).
The tag has a 7 or 8 digit ID code, like this: 603010-1 or this: 603010-11.
The AXLE code is stamped on the Warranty Plate, but Ford usually did not list front dtiving axle codes.
Old Jan 16, 2011 | 09:20 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Just pull the cover and look on the edge of the ring gear. Its printed right on it. Its either 354 or 410. Only the outer stub shafts are 30 spline. The inners are 35 spline
Feardeere7
13
May 13, 2014 10:38 AM
Hyperactive460
Feb 24, 2007 11:23 PM
4x4turboterror
Offroad & 4x4
13
Apr 24, 2005 11:20 PM
RedXL
Mar 19, 2003 03:46 PM
harper
Sep 12, 1999 09:37 AM
