flashing overdrive light
Old Oct 23, 2011 | 08:36 AM
jbs08's Avatar
jbs08
I have a 92 F-250 w/7.3 diesel. The overdrive light flashes and the truck shifts hard . Please help
Old Oct 23, 2011 | 09:28 AM
Ponyboychris's Avatar
Ponyboychris
Flashing O/D light means codes are stored and they need to be scanned for diagnostics.
Old Oct 23, 2011 | 02:51 PM
Bonanza35's Avatar
Bonanza35
I don't know where the speed senser is on the 92 but its on the rear axle on are superduties and that sometimes will cause hard shifting. Get those codes read like said above. Chet
Old Oct 24, 2011 | 10:37 AM
Studawg's Avatar
Studawg
Thread Ender
Check ALL your fuses first! My O/D light was flashing, and one of the MAXI fuses was blown, it was labeled "trailer" or "tow charging" something-something". I cant remember exactly and the truck isnt here. I do know it was a MAXI fuse though. Changed the fuse and no more flashing.
Old Oct 24, 2011 | 07:30 PM
Firefighter 1406's Avatar
Firefighter 1406
Yep codes, when mine was flashing it was shot and pukeing fluid all over the ground. Hope it's something simple for ya.
Old Oct 24, 2011 | 09:27 PM
rshosted's Avatar
rshosted
It means your torque converter slipped. It's normal under heavy loads but means it would be a good idea to let up the throttle when you know it's going to shift
Old Oct 24, 2011 | 09:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Maybe, maybe not. There are about 50 things that could make the OD light flash. A slipping torque converter is one of those.
There is no reason to left up on the throttle when it's about to shift.
Zack12
Dec 16, 2012 08:02 PM
ctruf1504x4
Apr 26, 2012 08:50 PM
mblanken881
19
Apr 10, 2009 08:39 AM
zed326
Jan 13, 2009 08:19 AM
highboy390fe
1997 - 2003 F150
Sep 1, 2006 09:43 AM
