Rear Cam Plug Second Request
Old Mar 29, 2010 | 11:41 PM
Hayesn's Avatar
Hayesn
Question Rear Cam Plug Second Request
I have a 65 F-250 With the 352 V8 and Std Tranny. I need the Plug that goes on tyhe back of the Camshaft. (In the block behind the flywheel). Can anyone tell me where I can get this part. The old one popped out and is stamped 2 3/8. I assume this to be the size. Is it correct. Any help is appreciated.
I have tried all the local parts stores and have had no luck. Can anyone tell me where I can find on and what is the actual size.
Thanks NH
Old Mar 30, 2010 | 02:37 AM
KULTULZ's Avatar
KULTULZ
Post
A NAPA or local machine shop should be able to get you one.
FORD PN is (was) 353001-S and it is 2 3/8" DIA.
Old Mar 30, 2010 | 10:54 PM
85e150's Avatar
85e150
Napa site:
Store Locator | NAPA Online
Is this the set that includes the cam plug? I see one larger steel plug, is that the feller in question? $13 for the whole set if that's the only way to get them....
Old Mar 30, 2010 | 11:20 PM
Hayesn's Avatar
Hayesn
Thanks for the help. I found one at Rockauto.. Dorman P/N 555054
NH
Old Apr 1, 2010 | 09:22 AM
Cyclone_416's Avatar
Cyclone_416
Just a heads up...
That particular plug goes in "backwards" on the FE compared to most other engines. I'm guessin you probably allready knew that but just thought I'd chime that in just in case.
Old Apr 7, 2010 | 06:23 PM
66shortbed's Avatar
66shortbed
backwards? does it really fit like that? i just installed mine the way i the other plugs are installed... you are saying i did it wrong? drag. how do you get it to drive in compress and seal?
Old Apr 8, 2010 | 01:28 AM
Cyclone_416
Well which end of the plug is facing the butt of the camshaft? If you were to take a water glass and flip it drinking side down, that's how the plug is supposed to go in on an FE. It isn't just a regular freeze plug either, it has a taper to it I believe. I think I just put a film of "The Right Stuff" gasket maker around the outside edge of the plug.
Old Apr 8, 2010 | 10:01 PM
Hypoid's Avatar
Hypoid
Right way, Notice the chamfer?
wahfulls
Modular V10 (6.8l)
17
Mar 28, 2025 11:26 PM
Mcrafty1
Apr 29, 2016 10:41 AM
BigBlocker0248
Jan 20, 2016 06:41 PM
SpedKid94
Jun 6, 2015 06:30 AM
johnny8
13
Aug 31, 2007 01:59 PM
