The dreaded broken door handle
Old Mar 29, 2010 | 09:59 PM
*2fords*'s Avatar
*2fords*
I like other here have the dreaded brken door handle. I've replaced it several times with both stock and aftermarket handles, and I even made one out of metal. i managed to break that one too.
I've read on here about the door flexing in that spot. I have watched that part of the door while useing the handle, and see no flex there. Nor do I see any cracks.
So this leads me to beleive the cable is stretched or stuck.
I have a donor truck that I can get the cable and a handle off of, What I need to know is how long the cable is supposed to be, so I don't get another stretched one.
Does anybody know how long it is or where I can get the info?
Thanks in advance.
Old Mar 29, 2010 | 10:14 PM
Nealcrenshaw's Avatar
Nealcrenshaw
interior or exterior handle?
Old Mar 29, 2010 | 10:20 PM
ron_a_tron's Avatar
ron_a_tron
pretty sure he's talking about the exterior, door flex
have not had any problems with mine cant help.
Old Mar 29, 2010 | 10:41 PM
TC-Countryboy's Avatar
TC-Countryboy
Door handle replacement, I imagine you are talking about the inside handle, just replace my handle and cable on the passenger side this past Saturday. Thought it was the cable, but it was actually the in the catch mechanism that was binding up. The lever that the cable goes to was frozen up from years of oil and dust. Degreased it and cleaned it up good and gave everything a good coating of Fluid Film and put it back together and it works like new. Biggest pain is getting the rods unclipped from the exterior door handle and lock. Not really as bad as I thought it would be, I had been putting it off for a few weeks.
TC
Old Mar 30, 2010 | 09:02 PM
*2fords*'s Avatar
*2fords*
Yes I was talking about the interior door handle. I guess I didn't make that clear. I guess I will take my door apart once I get my truck back from the shop and check to see if something is binding up like TC said. If it is something like that, it'll save me 22.00 bucks for a new cable, but I still need to replace the handle. I see that the 80 to 86 metal handles will work, so I will be getting me a set of those from NPD.
Old Mar 30, 2010 | 10:30 PM
TC-Countryboy
2fords,
Hope it works for you, I know cleaning the catch made a world of difference. In matter of fact, I might take the driver side apart this weekend and clean it up as well. Maybe it will save it from having a broken door handle on it someday. It works, but is stiff compared to the passenger side now.
TC
Old Mar 30, 2010 | 10:47 PM
Dean88's Avatar
Dean88
Get a door handle out of a the 80-85 F series, they're thick metal and I've never seen a broken handle in one of those trucks. Heck I ripped the mount out of the door metal in my F100 once cuz the latch mechanism stuck.
Old Mar 31, 2010 | 11:23 PM
jarod17's Avatar
jarod17
Sorry Dean but the metal ones while stronger will still break. I went through two of them. I do not have anything binding the rods. I went another route with mine. It required trimming of the door panel but has not broken yet.
I got the idea while at Cabela's. I took a .50 cal. dummy round, drilled out the primer, pulled the bullet off the caseing, bolted the caseing to the door, then put the bullet back on the caseing. Works great and hasen't broke yet for two years.
Old Jun 30, 2016 | 02:50 PM
95Fordf350's Avatar
95Fordf350
How did you fix the mount?
Old Jun 30, 2016 | 06:44 PM
Big_Al59's Avatar
Big_Al59
This thread is 6 years old, guy you're asking hasn't been active since 2013.
Old Jul 1, 2016 | 11:31 PM
f100today's Avatar
f100today
Funny I just went through this yesterday. Found a 96 CC 7.3 with only 92k on it. Got a fair deal because there were so many little things wrong the seller wouldn't fix. One of them being a broken drivers side door handle. Thats voodoo to a lot of people LOL. Anyway, I pulled the door panel off and removed the handle mechanism and sure enough, the metal where the nut clip inserts was cracked allowing the handle to flex too much. I didn't have time to make a backing plate but I did break out the welder and weld the cracks up. Works like a champ now.
Old Jul 2, 2016 | 12:51 PM
95Fordf350's Avatar
95Fordf350
Sorry newby
Hey thanks for the response I was just going through the forum and found that and didn't even pay attention to the dates.
I'm not a welder so I took a big washer and drilled a hole in it and put the clip around it and it's good and tight.
MustangMatt96GT
20
Feb 12, 2020 12:19 PM
humphrey169
Jun 15, 2017 08:59 PM
Texas Mad Man
Jun 9, 2017 08:05 PM
GuitarJesus
18
Mar 4, 2016 09:47 PM
supplementfacts
Feb 17, 2016 11:24 AM
