Side door handle fix
Old Jun 15, 2017 | 11:11 AM
humphrey169's Avatar
humphrey169
So after some searching I couldn't find any real good info on how to fix my sliding door. The outside handle didn't work and you had to open the front door to get to the inside handle. Knowing the cables are known to go bad I ordered some aluminum cable ends from eBay.
Old Jun 15, 2017 | 11:19 AM
humphrey169
Go get the inside panel off you have to take the top small cover off first. One screw
Old Jun 15, 2017 | 11:29 AM
humphrey169
Next the handle and the door lock extension comes off
Old Jun 15, 2017 | 11:34 AM
humphrey169
Then the two window latches
Old Jun 15, 2017 | 11:50 AM
humphrey169
Then the upper molding comes off. It's held on by metal clips on the door. They just pop off
Old Jun 15, 2017 | 12:23 PM
humphrey169
Then 2 screws hold the lower panel on. It pulls up after they are removed
Old Jun 15, 2017 | 12:26 PM
humphrey169
Next I found the cable end that needed replaced. I cut the rubber end off and replaced it with the aluminum piece
Old Jun 15, 2017 | 02:28 PM
humphrey169
That cable end was bad but wasn't my main problem. There's a screw on the back of the handle that had came loose
Old Jun 15, 2017 | 04:42 PM
humphrey169
I drilled a hole so I could get a screw driver on it. Removed the screw and added loctite. Reinstall everything and your in bussiness.
Old Jun 15, 2017 | 04:58 PM
EagleFreek's Avatar
EagleFreek
Nice tutorial. I had the same exact problem when I purchased my van. Both the cable end was broken and that screw was loose. I didn't loctite the screw the first time and it loosened up again after about a year. I Loctited it the second time.
Old Jun 15, 2017 | 05:02 PM
vettex2's Avatar
vettex2
Those pics will help many!
Thanks
Old Jun 15, 2017 | 08:53 PM
jimbomitch's Avatar
jimbomitch
Yes, thanks for taking the time to share this!
Old Jun 15, 2017 | 08:59 PM
humphrey169
Yeah no problem. Hopefully it keeps someone from breaking their panel from improper removal of just saves them money from paying someone to do it. Took like 10 minutes even with taking pictures.
StealthWyvern
Nov 21, 2014 07:16 PM
OQL
Feb 8, 2014 01:56 AM
B Big
19
Nov 9, 2010 11:15 AM
tcoates
Mar 4, 2009 05:43 PM
rclark1
Jan 9, 2007 10:30 AM
