Sponsored by: Auxito
Inserted heli-coil BUT...........
Old Mar 29, 2010 | 12:34 PM
dave200's Avatar
dave200
after rain, I still get code 358 which says coil. and truck is missing. Changed plug and coil again. Now I think I may not have installed the insert deep enough so my boot won't go all the way down. Does anyone have the measurement from top of valve cover to top of spark plug.
Because I'm thinking if the plug is not deep enough, I may cut 1/8" off the boot and try that to get it to seal that way. We've had a lot of rain and the code doesn't come right on, takes a little while.
Want my truck back running good.
2001 super crew 5.4L
Old Mar 29, 2010 | 06:00 PM
steve(ill)'s Avatar
steve(ill)
Dave, i though 358 code was a missfire on the power TOO the coil, not the coil output. NOrmally you will get a 308 ot 306, etc if the OUTPUT of the coil is bad... Not sure, but i vote aginst the helicoil being a problem.
Old Mar 29, 2010 | 07:42 PM
dave200's Avatar
dave200
Ok,..........
then how do I check the connector? Can I buy one and splice it on? or is the problem further away?
Thanks
Old Mar 29, 2010 | 10:36 PM
steve(ill)'s Avatar
steve(ill)
this might help, i cant.
obd2 code p0358 - JustAnswer
Old Mar 29, 2010 | 10:46 PM
steve(ill)'s Avatar
steve(ill)
from more reading it appears the 358 can be a coil problem on #8 cylinder. Normally you get a 308 code... you could switch #8 with the front one #5 and see if you get a different code??????
oxbronco
Modular V10 (6.8l)
Jun 24, 2013 04:57 AM
Justin's Green Truck
Mar 30, 2013 10:08 AM
sbubba32
Nov 26, 2011 02:03 PM
redhead_men
Modular V8 (4.6L, 5.4L)
Apr 2, 2008 10:22 AM
Davez99Expy
Mar 20, 2007 04:02 PM
