Coil on plug boot question. 5.4 modular
Old Mar 31, 2008 | 12:44 AM
redhead_men's Avatar
redhead_men
I replaced all my plugs and boots on a 1998 Ford E-250 5.4 engine. My new boots from Auto Zone do not seal tight at the top of the spark plug well. Is this normal?
I had discarded the original ones days before but I remember them fitting tight and not allowing the COP to rotate. I am now getting a misfire on #6 cylinder when it is raining or very damp. I used dielectric grease at the coil and plug end of the boots. Should I have gotten the boots from Ford for a tight fit? Thanks for any help or advice.
Old Mar 31, 2008 | 02:15 AM
LxMan1's Avatar
LxMan1
Welcome to the forum
I've never heard of any problems with the aftermarket boots. I would remove it and regrease it real good to see if that cures the problem.
You might also pull that plug and make sure that the porcelin isn't cracked.
Old Mar 31, 2008 | 12:32 PM
redhead_men
I know that you can rotate the COP about 20 degrees right or left with the new boots. Auto Zone said they are the correct ones. I think they would let in water in a hard rain.
Old Apr 2, 2008 | 10:22 AM
GRUSSON's Avatar
GRUSSON
i had the exact problem on my 99 5.4-could not get the dang things to seal and misfires on 2 and 5. i ended up getting factory boots on the motor 2 weeks later.
fixed the problem.
aftermarket parts from china!
factory parts from canada.
bob1987f
2004 - 2008 F150
Apr 17, 2013 06:18 AM
wchain
Jun 12, 2007 02:01 PM
Lance1601
1997 - 2003 F150
May 24, 2007 08:58 PM
xbwfo
Modular V8 (4.6L, 5.4L)
Mar 11, 2003 02:41 PM
