I was at a friends house last summer in Spokane WA. and he has the same 97 F250 powerstroke that i have, and his sounded awsome! He told me that he was running straight pipes, no cat or muf. Wanting the same, I had my cat and muff removed and replaced with straight pipe. Here's the problem, when its cold, instead of hearing the turbo wind up, it make a real loud sound, like a jet engine blow dryer. Once it warms up, it goes away and the nice turbo sound returns. It happens a lower rpms and when I increase speed it will go away. One more thing, if its really cold..say below 0.. it never goes away. Even after a 100 mile run. I live in Alaska now so my warm days are numbered. Do I need to put something back on to keep the pipes warmer, do I have a leak, or is it a turbo issue?
Could it be your exhaust back pressure valve (ebpv) ? I would guess that is what you are hearing. I unplugged the ebpv on my truck. The plug is located kind of under the turbo and intake plenum on the drivers side.
yes sir that is your exhaust back pressure valve. it closes in the outlet of your turbine housing and it warms up the engine. the computer closes the valve VIA high pressure oil to warm up the block, its essentially on because your engine and or oil is not warm enough. yyou probly havent noticed it as much before becuase you had your muff and cat on, but when your straight piped like 93% of us you will noticve it MUCH more lol
you can disconnect it by thethe 2 prong dongle on the under side of the compressor under the intake boot on the turbo. it wont hurt anything. its preffrence.
I wouldn't use it as a exhaust brake if you have an Auto trans. Heard that it can mess it up.
I use as an exhaust brake and have an auto, and works very well, just you need to add a lock up switch (to ground the torque converter) to work together, and no problems.
The range of the RPM, its better above the 2000 RPM but works well in most of the RPM, you just need to disconnect both (exhaust and lock up switches) before to stop, or the engine will stall.
