changing vacuum pump
Old Mar 31, 2010 | 07:58 PM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Originally Posted by kawa
Why was it necessary to change the pulley? A pulley is a pulley unless it's damaged. Of course, you wouldn't need a pulley puller if you installed a new pulley, but the cost goes up.
Please enlighten me if I'm wrong.
Rog
The reason is that you're not CHANGING the pulley. The pump comes without one so you are removing it from the old and replacing it on the new pump. remember to put those bolts in first
Old Mar 31, 2010 | 11:40 PM
kawa's Avatar
kawa
Talking
I understand what you are saying Jack but, my question was directed towards those that replace the pump and install a new pulley rather than reuse the old one.
Hence, a pulley is a pulley unless it's damaged. As action4478 indicated if the pulley has been R&R'd numerous times creating a loose, pressed fit then that is a damaged pulley. jmho
Rog
Old May 15, 2012 | 07:53 AM
trailriderjude's Avatar
trailriderjude
I love this forum, thanks for the good info. I took my truck to a dealer and they gave me a price of almost 500.00 to replace this vacuum pump, thank goodness my son's are mechanical enough to do it for me. After market pump from KOI for seventy something, big difference!
Old May 15, 2012 | 09:35 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
First of all WELCOME to the forum. You woke up an old thread, but is fine to hear that it helps you.
Old May 15, 2012 | 07:24 PM
yoslick's Avatar
yoslick
And not one mention of checking the lube in the pump?????? Seen 3 from NAPA that came completely dry...... ymmv.......
Old May 15, 2012 | 10:24 PM
LeoJr's Avatar
LeoJr
What lube? How do you check it? (Am I being punked?) I just changed mine...
Old May 16, 2012 | 06:59 AM
yoslick's Avatar
yoslick
Allen head screw, remove, put in good oil (I use synthetic) put screw back in.
Old May 16, 2012 | 07:40 AM
LeoJr's Avatar
LeoJr
Can I do this while the pump is installed?
Thanks!!
Old May 16, 2012 | 08:10 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I dont see any Allen head screw in the pics of the link I posted (post #9)
Old May 16, 2012 | 05:00 PM
BuckHammer's Avatar
BuckHammer
Where on the pump is the screw located? Also, what sort of oil would I use. Engine oil?
scottrobert
Oct 27, 2015 09:22 AM
flipklos
19
Sep 17, 2012 05:17 PM
Jaaaaaaackman
Mar 10, 2012 08:53 PM
rugermack
Jul 25, 2008 09:13 PM
19Ford69
Feb 15, 2004 07:12 PM
