Vacuum pump pulley
Old Mar 10, 2012 | 12:15 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Vacuum pump pulley
How does one remove the pulley from the vacuum pump pulley?
Got a new pump coming minus the pulley.....
Old Mar 10, 2012 | 12:23 PM
BlueMule's Avatar
BlueMule
Use a power steering pump pulley remover/installer that you can rent/borrow from the parts store.
Old Mar 10, 2012 | 12:54 PM
Jaaaaaaackman
Thanks I'll see what AutoZone has for rentals.
Old Mar 10, 2012 | 03:13 PM
DRRXR's Avatar
DRRXR
Be sure to get the bolts in there before pressing it back on.
Hi Rodney
Old Mar 10, 2012 | 03:44 PM
Jaaaaaaackman
Hi Rodney
Good point , Still not finding any info on removing or installing the vacuum pump pulley , while looking at the pulley its not clear what holds on the pulley (no nut or bolt) or how to remove it,,,,,,, any info is appreciated!
Old Mar 10, 2012 | 03:57 PM
Ken_C's Avatar
Ken_C
its what we call "press fit" because it has to be pressed on. do what rodney said and get the power steering pump pulley tool. nothing holds it on because a press fit is so tight.
Old Mar 10, 2012 | 04:02 PM
DRRXR's Avatar
DRRXR
Remove vacuum pump pulley using Steering Pump Pulley Remover T69L-10300-B.
Remove vacuum pump bolts.
Disconnect vacuum pump hose and remove vacuum pump (2A451).
INSTALLATION
Connect vacuum pump hose and install vacuum pump.
Install vacuum bolts. Tighten bolts to 23-32 Nm (17-23 ft lb) .
Install vacuum pump pulley using Steering Pump Pulley Replacer T65P-3A733-C.
Its been a while since I did mine. I cant remember if I pulled the fan out of there or not to get to it.
Item Part Number Description
1 N605790-S2 Bolt, Vacuum Pump-to-Bracket
2 2A451 Vacuum Pump
3 3A674 Power Steering Pump
4 26487 Vacuum Pump Pulley
A -- Tighten to 23-32 Nm (17-23 Lb-Ft)
Old Mar 10, 2012 | 04:10 PM
BlueMule's Avatar
BlueMule
Here's what the tool looks like:
Don't try pulling it with a 2 or 3 jaw gear puller or you will destroy the pulley.
Hey Rock. How's it going?
Old Mar 10, 2012 | 04:12 PM
DRRXR's Avatar
DRRXR
Nice pic Rodney
Its gotta be going good since we get more daylight tomorrow. But loose a hr of sleep tonight.
Old Mar 10, 2012 | 04:58 PM
Jaaaaaaackman
Thanks guys , I crossed refrance the tool number at Autozone to tool rental # 27031, its in stock and on hold.
Thanks
Old Mar 10, 2012 | 05:01 PM
Jaaaaaaackman
Reps sent to you guys, Thanks
Old Mar 10, 2012 | 08:53 PM
Iallwork's Avatar
Iallwork
Nice pic Rodney
Heck with daylight savings. I'm sticking to the old schedule.
RenoHuskerDu
Jul 17, 2018 11:02 AM
kyle j
Aug 5, 2012 11:37 PM
rollingthunder-1
Oct 28, 2008 09:43 PM
scottie2hottie
Apr 6, 2008 09:16 PM
Slopetruck
Jan 4, 2008 06:17 PM
