Distributor and vacuum advances
Old Feb 15, 2004 | 09:21 AM
19Ford69's Avatar
19Ford69
Hey Guys,
I just posted a thread about my carb problems and I figured I'd open another thread about my distributor. My distributor has what appears to be 2 vacuum ports on it. I'm not 100% sure which is the vacuum advance and what the other one is?
I'm kinda sure the first vacuum port on the front of the bell looking thing out from the distributor is the vacuum advance port but there is another one that sits pointing towards the hood (when closed). What is this for? I have a vacuum guage/pump but haven't hooked it up yet to see if by pulling vacuum if it changes anything.
Why would there be 2 vacuum ports on a distributor?
Thanks for the help Bill
Old Feb 15, 2004 | 09:30 AM
oldiron's Avatar
oldiron
The second port on the dist. is a retard port. i.e. when you let off the throttle it actually retards the timing in the same way that the advance port will advance timing as the throttle opens or load increases. It was an early way to deal with emissions restrictions.
Greg
Old Feb 15, 2004 | 09:34 AM
19Ford69's Avatar
19Ford69
Is it necessary to run with it? Could I just plug it or will I need to have it? I am having issues with a stalling problem coming back to idle from a WOT in my other thread on my carb issues. Thanks for the info.
Bill
Old Feb 15, 2004 | 11:28 AM
oldiron's Avatar
oldiron
I don't believe it's necessary. You could eliminate the problem all together by using a 70-71 dist with a single vacuum advance.
Sounds like your stalling problem is more likely carb related.
Greg
Old Feb 15, 2004 | 12:15 PM
19Ford69's Avatar
19Ford69
Yeah, sounds like my carb and the rebuild I did on it is crap. Thanks for the recommendation for the different distributor. Anytime I can cut out a possible vacuum leak the better.
Bill
Old Feb 15, 2004 | 12:24 PM
rainbowATF's Avatar
rainbowATF
You might be able to just buy a new later model vacuum can with one port to retrofit your 69; if new dist not in budget.
Old Feb 15, 2004 | 06:48 PM
oldiron's Avatar
oldiron
I just dealt with that this weekend. A new advance cannister was 22.90, a new dist was 31.99, and it came with new points.
No brainer to me.
Greg
Old Feb 15, 2004 | 07:12 PM
mhg's Avatar
mhg
when it becomes time to upgrade check out gofastforless.com
there is some neat and cheap upgrades there
BigSexy78
Feb 4, 2017 06:06 AM
grandpas1974
Apr 8, 2016 11:34 AM
LA5054
Feb 16, 2016 08:19 AM
alchemist1
Jun 27, 2013 04:08 AM
1986F150six
Feb 10, 2012 08:27 PM
