She's gone!
Old Mar 27, 2010 | 07:31 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
When you're done with yours, wanna do mine? I'll help too...lol
Old Mar 27, 2010 | 07:34 PM
cheezit's Avatar
cheezit
some times help like that takes longer. The engine mods will done in about 2.5 days including a complete reseal do to a bedplate. Im also not worried about my warranty being cancled for some reason.
Old Mar 27, 2010 | 07:37 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I was only kidding, I know my fat **** and twinkie fingers would only get in the way
Old Mar 27, 2010 | 08:45 PM
gotfu's Avatar
gotfu
"update hpp and do away with stc fitting"
Cheezit
Could you expand on this as I am right in the middle of tearing the top end off my motor and have never heard of doing away with the stc fitting.
Old Mar 27, 2010 | 09:36 PM
rickatic's Avatar
rickatic
I am not Cheezit but I can help. The STC stands for snap to connect and refers to the attachment method used on 2005 and up 6.0 engines to connect the HPOP pump(high pressure oil pump) to the supply for the oil rails under the valve cover. It does not apply to your 2004.
Regards
Ricatic
Old Mar 27, 2010 | 09:49 PM
cheezit's Avatar
cheezit
what he said about the stc . the new style is a "T" block we have only seen a few fail and all theone that have have been to the o-ring seal being damaged durring install.
Old Mar 27, 2010 | 11:23 PM
Randy777's Avatar
Randy777
So Cheezit how do you drain your torque converter? Does it involve dropping your transmission?
Old Mar 27, 2010 | 11:24 PM
cheezit's Avatar
cheezit
with the engine out of the frame rails its just reach in and remove
Old Mar 27, 2010 | 11:26 PM
Randy777's Avatar
Randy777
Thanks, I knew it wasn't going to be easy.
Old Mar 28, 2010 | 08:19 AM
gearloose1's Avatar
gearloose1
Originally Posted by cheezit
you know Im getting ready to pull my engine out. I may just do some connector cleaning. Im in with you 500k is my goal.
in the comming weeks.
studs
full egr delete
3.5" free flowing pipes.
new oil cooler
drain trans and torque converter.
update fuel pressure regulator
update to latist revision of oil rail plugs with teflon washers
update stand pipe with to new with teflon washers.
gauges but in my case its hard because I would want way to many of them... It might look like the inside of a honda when im done.
and maybe a coolant filter.
and I sent an email off about tunes still tring to figure out who I really want to use and were I want to be hp/tq wise as dd.
Well, if you are going to do all that, and not do these steps below, I am going to send a bunch of unemployed Navistar assemblers down to throw casting sand at you!
- Every wiring harness should be checked for suspicious chafes or signs of failure (e.g heat damage, bend / breaks).
If possible, reroute all wiring harness away from heat and vibration, if needs be, install a heat shield or put the loom in a conduit.
- Every connector / plug cleaned, removing all grease and corrosion. This can only be done with clean hands!!!
Then, if the connector has a spring loaded element (like the 2 round ends that hook onto a flat blade contact), tighten it with needle nose pliers to ensure a good, solid contact.
If the connector uses pins, clean all pins, and use the Ford dielectric grease to lubricate it.
If you want to get real snazzy, use silicon spray to lube the wire loom on the inside.
When wiring and connectors are reinstalled, they should be twist tied so as to minimize flex / vibration BUT NOT to cut out intentional flex to prevent breakage.
e.g. the wires to the doors are intentionally done with a length vertically to allow flexing over about 4" to reduce the chance of the wire being overflexed at one point.
If you have any doubt about the wiring, either replace the harness (safe), or get out the VTVM and start testing.
Often a failing harness will test fine, only to die in actual use.
If you have lots of known good sensors lying around, I would consider a package deal to simply throw out every sensor / actuator....
caverjoe
Jan 2, 2016 07:07 AM
Turbolover64
26
Feb 2, 2014 06:54 PM
snowjaw
47
Feb 8, 2012 08:12 PM
twtcad
76
Mar 23, 2011 09:24 PM
Fully_Loaded
Nov 17, 2010 05:42 AM
