97 explorer power window
Old Mar 26, 2010 | 03:38 PM
Carmine1913's Avatar
Carmine1913
The front passenger window on my 97 Explorer stopped working in the down position. Some history, the switch stopped working several years ago but the driver could operate the window, so no big deal.
Since all the other windows work, I assume the relay is good and the fuses are ok. I hear nothing when I activate the switch. Should I start with the motor?
Not sure if this is related, but the rear wiper motor stopped working a few months ago as well.
Old Mar 26, 2010 | 05:05 PM
Moto Mel's Avatar
Moto Mel
You need to pull the door panel and using a multimeter have someone operate the dr. door switch, if there is power to the motor you need a new motor. Also, many explorers have problems with the wires in the rubber boot between the door and body breaking. If you check there you may find the original problem.
Old Mar 27, 2010 | 12:30 PM
Carmine1913
Mel: It was the motor, found some helpful hints on some other threads and got it swapped out. I guess it is time to tackle the rear windshild wiper. Thanks for the tip.
Old Mar 27, 2010 | 12:44 PM
Moto Mel's Avatar
Moto Mel
Is it now working with the rt. door switch? Or still only the dr. door switch?
Old Mar 28, 2010 | 01:16 PM
Carmine1913
Now I have another problem; I have power all the way to the motor thru the drivers side switch but the new motor is still not working. I even went back to the shop and they replaced it but still no go.
Old Mar 28, 2010 | 09:25 PM
Moto Mel's Avatar
Moto Mel
Check your ground or run a seperate ground from the battery. The ground is one of the wires that often break .
66ca
Jun 13, 2010 02:30 PM
Penton97F150
Electrical Systems/Wiring
Jul 31, 2007 12:10 AM
Xxbronco90xX
1978 - 1996 Big Bronco
Nov 28, 2005 09:31 PM
nosbor
Feb 1, 2004 12:25 AM
ottosmom
Jan 12, 2004 02:05 PM
