E-Fan thread
Old Mar 25, 2010 | 08:47 PM
Bayer-Z28's Avatar
Bayer-Z28
E-Fan thread
I figured we could try to throw a chunk of this E-Fan conversion info into one thread..
I picked up a coolant fan out of a Mercury Sable at the junk yard for $25 today. Looks like it should drop right into place.
NOW here are the questions:
-What have you guys done about a temp-fan switch? NAPA? 180*? 190*?
-How many fans should we use? One or Two? I know the secondary fan is for the AC.
- Can we buy two flat fans from Summit or somewhere?
-How did you mount the fan(s) to your RAD?
-Can you just T off of the AC Comp clutch wire to trigger a solenoid for the AC??
I'll post a pic of my fan tomorrow. Got the whole shroud and wire pigtail. Pics from your setups will help also.
Old Mar 26, 2010 | 07:40 AM
Bayer-Z28's Avatar
Bayer-Z28
Anyone? I know I'm not the only person doing this.
Old Mar 26, 2010 | 08:32 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...onversion.html Have a look here. Other than that I can`t help.
Old Mar 26, 2010 | 10:19 AM
l67cooled's Avatar
l67cooled
As for temp switch I use an adjustable temp switch. Very easy to adjust to your liking.
I use a single fan with dual speeds. Although I do not have mine hooked up to my AC because my ac is not functional.
Summit does have smaller fans that run parallel.
My fan had to have brackets fabricated to bolt in place. I just had some scrap metal laying around and did the necessary bends to make it work. I don't know how your electric fans shroud looks but a little engineering will make it work.
Yes
Sorry no pics of my setup.
Old Mar 26, 2010 | 05:34 PM
Bayer-Z28's Avatar
Bayer-Z28
How would one go about setting up dual speeds? Resistor on one side and full open on the other?
I can fab stuff no problem.. and I have great access to sheet metal.. I'm brewin up an idea already..
-=EDIT=-
Gonna order some stuff from Jegs..
Adj Fan controller
http://www.jegs.com/i/JEGS/555/52125/10002/-1
Ieew.. E Fans thru Jegs are pricey.
Sweet.. just got the Fan controller and a relay setup with a circuit breaker. Total for this fan conversion; $70.
Old Mar 26, 2010 | 09:58 PM
Hitokori's Avatar
Hitokori
i used e-fans off a 95 firebird
Old Mar 29, 2010 | 11:39 AM
l67cooled's Avatar
l67cooled
-=EDIT=-
Adj Fan controller
JEGS 52125 JEGS Adjustable Temperature Control Switch
That's the same controller I have. Paid $7 for it at o'reilly auto parts. As for the dual speed I think once you hook your condenser up it will notice the extra demand and kick up higher or override the temp control and run constantly. I"m not sure though since don't have my condenser hooked up ( ac don't work )
Old Mar 29, 2010 | 06:18 PM
Bayer-Z28's Avatar
Bayer-Z28
^ Parts will be here tomorrow. Where did you put the temp probe? I've seen it before where you can stick it in the fins of the radiator, but I'm not sure if my 1995 Stock radiator will like that too too much. I was thinking about making a T adapter out of PVC to splice into the top coolant hose. I don't have a plastic welder though and I don't think PVC Adhesive/Epoxy will hold 12lbs @ 210*.
Old Mar 30, 2010 | 08:22 AM
Bayer-Z28's Avatar
Bayer-Z28
Anyone know where to put the temp probe?
Old Mar 30, 2010 | 12:45 PM
l67cooled's Avatar
l67cooled
That style temp probe will just have to rest up against the radiator, you do not stick it into the fluid by any means. It will have a mounting kit that does poke through the radiator to support the probe against the fins. From there you will accurately determine what temp you want it to turn on at. Easy way is to let the truck warm up to operating temp and adjust the fan to kick in, then bump the temp up a notch, so it turns on just over desired operating temp. Readjust if needed.
If you need a pic I can take one tonight when I get home.
Old Mar 30, 2010 | 03:10 PM
l67cooled's Avatar
l67cooled
Here's a link with a wiring diagram. Just thought it might help
FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs
Old Mar 30, 2010 | 03:47 PM
Bayer-Z28's Avatar
Bayer-Z28
^ Ah thanx bro.. I'll just stick the probe in the rad fins near the top hose somewhere. I'll have to pick up a temp laser thing. I need one for my Nitro RC truck anyway. I'm also curious to see what temp the coolant/rad is at the bottom and opposite end. Wondering how efficient it is without the fan.
OldWoodsDiesel
15
Sep 3, 2014 06:08 AM
joegeds
Mar 5, 2014 08:06 AM
quincyj34
Feb 26, 2014 10:27 AM
cje07
1978 - 1996 Big Bronco
24
Mar 28, 2010 08:45 PM
wendell borror
1983 - 2012 Ranger & B-Series
30
Aug 13, 2006 07:30 PM
