Can't figure this out.
Old Apr 8, 2010 | 10:18 AM
  #31
oldbird1965's Avatar
oldbird1965
So, is this a good thing to have done?
Old Apr 8, 2010 | 10:39 AM
  #32
Cuda_jim's Avatar
Cuda_jim
I read through the posts kinda fast so forgive me if this has been covered already.
Have you checked the EBPV. When it closes the engine will be a real dog.
Have you disconnected the EBR yet? (First Pict). You don't need it unless you live in the Arctic. If you suspect it's closing it can be wired into the open position. Take a look:
Old Apr 8, 2010 | 10:57 AM
  #33
cowmilker08's Avatar
cowmilker08
Well it guarantees that your pcm isn't causing whatever problem you may be trying to solve.
Old Apr 10, 2010 | 10:07 PM
  #34
Cobra Highboy's Avatar
Cobra Highboy
Well I got it fixed today. I found a major oil leak right where the dip stick goes into the oilpan and I had lost 6 quarts so needless to say the computer was shutting the engine down. I did rebuild the IPR and found a broken O-Ring so that is a good thing. It runs awesome now.
Thanks to every one for your help.
Old Apr 10, 2010 | 11:59 PM
  #35
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Do you think it was mostly the low oil or the orings?
Old Apr 11, 2010 | 10:55 AM
  #36
Cobra Highboy
I think the low oil but I think the O-Rings helped too cause it feels like it has a little more power than it used to.
CG-ITS
Feb 5, 2016 03:17 PM
SuperDutyScaler
Apr 23, 2014 06:15 PM
AndeyHall
Feb 12, 2010 08:18 AM
uofmgriz
Feb 10, 2010 09:42 AM
cr0wnn7
Computer Chips & Tuners
Sep 13, 2005 05:19 PM
