headlight removal help
Old Mar 23, 2010 | 11:31 PM
rolltide3006's Avatar
rolltide3006
Trying to remove pretty much everything up front to make room for the new intercooler. I guess Ford decided to make it as hard as possible to remove headlights and the big piece of black plastic that holds them on . Does anyone have any pointers? It looks like there are clips that would need a spanner wrench up near the hood latch. Do I need to remove these?
Old Mar 23, 2010 | 11:39 PM
strokin'_tatsch's Avatar
strokin'_tatsch
to remove the header panel(big piece of black plastic) there bolts that bolt it to brackets on the radiator support i thought. kinda tough to see them. don't take the headlights off the header panel, they come out with the panel. if your changing the headlights then they are easier to take off with the header panel off the truck anyways. the headlights have clips on the backside that have to slide off and are a PITA. hard to describe where the bolts are for the header panel...
Old Mar 24, 2010 | 12:08 AM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
I'm struggling with the same deal. There's 2 11mm nuts on studs that you get from in front of the battery trays holding the headlights on I think. Wheres the PITA clips?
Old Mar 24, 2010 | 12:39 AM
strokin'_tatsch
the headlights are held onto the header panel by the PITA clips, not bolts i don't think. they are on the back side of the header panel and are tighter than a gorillas fist to get out. thats why u take 'em out with the header panel and then work on them on the bench. there are 3 studs with nuts that hold on the turn signals and stuff i thought?
Old Mar 24, 2010 | 07:05 AM
Cudaguy's Avatar
Cudaguy
It's not that big a deal, but the whole panel has to come off with the headlights on. The headlight clips are impossible to remove while on the truck. each side has two 11mm bolts that you access in front of the batteries which hold the sinal lights in place. Remove these, and the remaining bolts are easily accessed from the front, and think are 8mm. The grill will also have to come off. The hardest part are the four 11mm bolts, but even that's not that big a deal once you find them. Removing the plastic strip in on top of the radiator support makes it easier to find all the bolts.
Old Mar 24, 2010 | 08:00 AM
Action4478's Avatar
Action4478
This may help ...[ATTACH]Name:  HEADLIGHT HIDDEN NUTS.jpg
Size:  34.5 KB[/ATTACH]
Old Mar 24, 2010 | 09:21 AM
Jacksfirstdiesel
thanks action4478. You posted this some time ago. I found it in a search and it helped me find these ones playin hide and seek.
Monana ford Man
Jan 9, 2012 07:33 PM
Trojan8975
Aug 15, 2011 03:48 AM
HowieE
Electrical Systems/Wiring
Nov 11, 2009 11:07 PM
NBFDCap
1997 - 2003 F150
Sep 3, 2008 05:12 PM
chennen
Jul 23, 2004 12:17 PM
