Head Light Removal Help
Old Aug 14, 2011 | 04:55 PM
Trojan8975's Avatar
Trojan8975
I am replacing the radiator support on my 1992 Ford Nite, but I cant figure out how to remove the headlights. I feel like a dumb *** for asking, but I need help. I already removed the grill.
Old Aug 14, 2011 | 05:45 PM
wattspd's Avatar
wattspd
After you remove all the trim, turnsignals, and so on there are clips behind the support kinda like c-clips holding them in.
Old Aug 14, 2011 | 06:30 PM
Trojan8975's Avatar
Trojan8975
And how do I remove the trim and headlights?
Old Aug 14, 2011 | 08:22 PM
xc4jokestomper's Avatar
xc4jokestomper
leave the headlights on the plastic piece. the turn signals and park lights come out by two bolts on the inside of the engine bay. their kinda hidden. im sure someone on here will post you a pic. feel down around below the headlight plug in and you should be able to find them.
Old Aug 15, 2011 | 03:48 AM
wattspd's Avatar
wattspd
Be careful when you undo the nuts for the parking lamps because it will strip out the studs of the housing because they are old and brittle.
Undo the the top screws of the headlight trim. There are two nuts under the headlight behind the lower turn signal that will let you remove the trim, marker light, and turn signal as one unit. Then you can pull the clips that hold the headlight in place.
mtn dew brent
Dec 28, 2010 11:51 AM
MrWillys
May 25, 2009 08:17 PM
ExcursionUSA
Mar 17, 2009 04:15 PM
5.8turtle
Jan 19, 2005 08:04 PM
quadman
Mar 2, 2003 08:56 PM
