rebuilding a C6
Old Mar 23, 2010 | 03:56 PM
b_eastep's Avatar
b_eastep
rebuilding a C6
iv searched but couldnt find anything. are there any special tools needed to rebuild a c6?
Old Mar 24, 2010 | 12:56 PM
mcdonaldm's Avatar
mcdonaldm
short answer yes. there are 2 special tools for compressing the clutch pack in the drums to remove the snap rings. but you can either build a tool to do this or use c-clamps intstead to compress the clutch packs instead. if you buy the Hayes manual it shows the special tools and also how to use the c-clamps to do the same thing.
you don't really need to buy the tools if you are just doing one transmission.
rgds
Mike
Old Mar 24, 2010 | 02:56 PM
b_eastep's Avatar
b_eastep
thats the answer i was looken for. thank you. any advice on books or dvd's on this subject would be great. this will be my first tranny rebuild. poor boy cant afford $500 for a rebuild.
Old Mar 24, 2010 | 04:52 PM
compman25's Avatar
compman25
This book works Haynes Techbook ISBN: 1563924242 Part# 10355 : eBay Motors (item 230410321744 end time Apr-08-10 10:41:42 PDT)
Old Mar 25, 2010 | 10:45 AM
b_eastep's Avatar
b_eastep
thank you sir. will order today. can anyone tell me realisticly how hard it is to rebuild a c6 without the specific tools? very mech inclined just never done it before and dont wana take a box of parts to a tranny guy if i get in over my head.
Old Mar 30, 2010 | 09:11 PM
b_eastep's Avatar
b_eastep
got that book today. not sure if im brave enough yet.
Old Mar 31, 2010 | 10:17 AM
mark a.'s Avatar
mark a.
I made these years ago for compressing the springs. I have no idea how you could use C clamps to do this job. You will need a dial indicator and a magnetic base to check the gear train end play. The piston seals can give you some trouble. Get the right assembly paste & just goop them up good and take your time getting them in. I try to avoid using any feeler gages on them if possible. Always check your clutch pack clearances. Flush the output shaft out real good, there will be a lot of old fluid left in it. Other than that it's easy, just be careful with the valve body, be ready for the check ***** when you separate it. Keep everything in order and take pictures if you have a camera. Always do a air check before putting the valve body back in. Before putting the trans back in make sure you flush the lines and cooler real good. You don't want any left over crap going right back in your fresh rebuild.
Old Mar 31, 2010 | 08:20 PM
b_eastep's Avatar
b_eastep
thanks for the info. think ill read the book and ill probly get a lot braver.
txlegman
Feb 6, 2007 01:45 AM
yomow
Jan 10, 2004 08:55 PM
JoeyH
Aug 29, 2002 02:00 AM
MustangGT221
Jul 22, 2002 08:30 PM
