Changing ratios in an 80 "9 in." E150 diff
Old Mar 25, 2010 | 03:56 PM
econocratemutt's Avatar
econocratemutt
Im running a 3.07 rear, w/ cast iron 3sp +OD. Geared too tall for my use.
3.73 pencils in right. Ive built engines & trannys and more, sucessfully, over the years but never touched a rearend. Lowest bid so far is over $500, aint worth picking up 500 rpm or so.
I got a mitchells thats gives the general procedure for assembly/disassemby. I need a "for dummies" version.....I was THINKIN< MAYBE, doing it myself but it looks like a few special shim operations ae required, and special tools.
The junkyards around here got highly inflated ideas about what stuff is worth....
Should I forget it? The idea was better mpg, since at cruise (60) is be in the middle of the powerband, and pulling high vac, than now, about 1700 rpm.
Thus cheap figures in......payback in better mpg, but just a bit. maybe.
Its a 2bbl 4.9, headwork, & other mods.....
Old Mar 25, 2010 | 11:45 PM
85e150's Avatar
85e150
Do the math. You might save some gas, but you'll have to wait quite some time to save money.
I had 3.50s and 31 inch tires with that POS trans and it was too tall so I feel your pain. 30 to 50 mph up a hill with a load is just a dream, ain't it?
Read through this, found up top under "Articles/Specs":
Ford 9 Inch Rebuild/Gear Setup .: Articles
I paid the $450 when mine started to whine. "The 9" Experts" they said. Took them 5 tries to get it so the new one didn't whine. At least they stood behind their work, but what a pita.
Old Mar 30, 2010 | 12:49 PM
rockher_man's Avatar
rockher_man
Question Hey...mutt....
....just curious....where is "around here" ??????
Old Mar 31, 2010 | 10:23 PM
csangster's Avatar
csangster
Junkyard third member
I've had great success pulling 9" third members from the You Pull-it yards. The yards around here charged $75 bucks for each pumpkin you pulled. Heck, I even scored a Nodular center section with the big fat N on it.....what a screamin' deal.
You might have a hard time finding a 3:73.......but I bet you could find a 3:55 pretty easy if you look.
For $75 and a few hours of your time for searching, it might be worth it to just pull yours and stick the junkyard member in and see how she behaves.
MTC,
Chris
onug
2015 - 2020 F150
93
Sep 15, 2019 11:38 AM
Henry42
Jan 26, 2016 09:53 AM
Frank Murch
1983 - 2012 Ranger & B-Series
Dec 25, 2015 06:47 PM
LittleRadio
Aug 9, 2014 08:01 AM
Mallie
6.4L Power Stroke Diesel
59
Sep 12, 2008 10:06 PM
