Modular V10 (6.8l)
Whirring sound on strong acceleration
Old Mar 23, 2010 | 11:58 AM
E350North's Avatar
E350North
We've got a strange sound that we're trying to diagnose on our 2005 E350. When we accelerate to get up to speed quickly, we get a whirring sound that seems related to the rpms. It's not related to driving. This also happens without being in gear. The higher the rpms, the higher the pitch. When the rpms lower on the gear change, the pitch also lowers. The sound goes away under normal driving/accelerating. So, once we're up to speed, everything sounds fine.
With the doghouse off, it sounds as if the noise is coming from right of center (from facing forward inside the van perspective). It also seems to be coming from the plastic housing related to the manifold. But we could be off on exactly where the sound is coming from. (Diagnosed with a heater hose as a stethoscope.)
The noise itself almost sounds like a bathroom fan where the bearings are going. Sorry for the less-than-technical definition. Again, it's only heard under strong acceleration. The odometer is just under 100,000 miles.
Also, the engine light has been on a while. Not sure if it's related. The code scanner says P0446. I've looked around and think I know what needs to be done with that (we live in the country - lots of dust, mud, etc - so I'll be cleaning out the EVAP cannister).
Any suggestions?
I'll try to post an audio clip soon.
Thanks!
Old Mar 23, 2010 | 10:08 PM
NM04FORD's Avatar
NM04FORD
My Brother in laws truck has a noise kind of a tinny sound that shows up under (hard) acceleration in the upper rpms right before a shift. He has never done anything about it, but we are pretty sure it is the inspection plate on the tranny. I read on here at one time the plate is made of very thin sheet metal on the earlier trucks. He has a buddy that had the same sound on a F150 also. I think the fix for it was to remove it, test drive to see if the noise is gone. If it is make the plate out of thicker material, or put a slight bend in it.
Old Mar 24, 2010 | 03:19 PM
E350North's Avatar
E350North
Where is this transmission inspection plate located?
Also, listening to the noise again reminds me of someone ripping lumber with a skillsaw. Again, the pitch changes with the rpms.
I've got the audio... just need to find a place to upload to.
Thanks
Old Mar 24, 2010 | 08:32 PM
NM04FORD's Avatar
NM04FORD
Just went out and looked it is right behind the oil pan on the front bottom of the tranny, looks to to be 2 bolts holding it in place about 1/2" wrench. It may not be the problem but worth a try.
Old Mar 26, 2010 | 11:01 PM
E350North's Avatar
E350North
Any more thoughts?
Old Mar 27, 2010 | 10:38 PM
NM04FORD's Avatar
NM04FORD
I have nothing else. Maybe someone else will chime in. If you find the source post it. Good luck.
Old Mar 28, 2010 | 09:29 AM
BareBones's Avatar
BareBones
I'm going to chime in with a non-standard bit of information. A few years ago I had a vaguely similar situation that I tracked down to a broken weld an exhaust pipe support.
It was actually quite easy to fix, but there would have been no harm done if I had just left it alone.....
Maybe you could better define "hard acceleration"? I.e., Is it "hard" because you get on it quickly, or do you mean just any time you're around 3/4 throttle, like maybe going up a hill?
In the one case I guess there could be some engine/transmission movement, whereas otherwise maybe its just an accessory like alternator or power steering pump?
Old Mar 28, 2010 | 11:59 AM
E350North's Avatar
E350North
Thanks for your input guys. If I'm easy on the accelerator, I typically won't hear it. But when I'm trying to get up to speed faster, then it shows up. I'll try to isolate the noise again today. But as it stands, it seems to be coming from the top side of the engine, midway forward, and to the right, from inside the van perspective.
Old Mar 28, 2010 | 08:51 PM
NM04FORD's Avatar
NM04FORD
Like barebones said check the exauhst. I have a heat shield rattling on our Taurus driving my wife nuts, using a rubber mallet and tapping on the exuahst under the car I have found 2 loose heat sheilds. I used a hose clamp to fix one but the other is in a place I cant get to. Check all the heat sheilds.
Old Apr 2, 2010 | 03:25 PM
Pete Magnus's Avatar
Pete Magnus
I had the same supercharger whine on my 99 F350 V10. Turned out it was my idle pulley that sits on top of the motor. I had all sorts of horrible thoughts when I heard the high pitched whine. I raised the hood and had my wife throttle up the engine and thats were the whine was coming from. I sprayed some good old WD40 on it and it stopped. That was 3 months ago and it hasn't come back.
Old Apr 9, 2010 | 08:37 PM
E350North's Avatar
E350North
Replaced Idler Pulley. Solved. The bearings were going.
Thanks.
Old Apr 10, 2010 | 08:30 AM
Rugby3's Avatar
Rugby3
Glad to hear it was solved, the symptoms sure sounded like a loose heat shield on the exhaust.
BusyDad
16
Apr 14, 2017 02:04 AM
ARW
17
Feb 15, 2017 06:59 PM
abe
38
May 11, 2016 12:08 PM
angelhazelnut
1997 - 2003 F150
Jul 31, 2012 09:33 PM
