Sponsored by: Real Truck
07 headlight conversion
Old Nov 12, 2010 | 10:12 AM
grec-o-face's Avatar
grec-o-face
I did the conversion over a year ago. I went with HD style lights though, to keep the black theme going. I bought the lights from my local aftermarket supplier and the quality is very good! Also, sticking with the DIY aproach, I bought 9007-H13 adapters on ebay. I did have to do some cutting/splicing, but I'm used to it. I think I did the whole job for less than $140. Then I added HIDs and strobes - the price went up! I cut my 99-04 header panel with a dremel - again, not wanting to spend the money on the 05-07 piece. Took me about an hour for the first side, and about 15 mins for the second.
Old Nov 13, 2010 | 08:50 PM
9402fordguy's Avatar
9402fordguy
Talking
Thanks a lot
Old Nov 15, 2010 | 09:31 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by scottzj
There is nothing else needed for this mod other than trimming the header panel behind the light. Everything else is plug and play and has been working on mine for quite a while now.
Really? I am not doubting you, Scott, just curious. I contacted the seller once before on this and he said, "yeah, you have to by the clips and bolts for the top of the lights." I can't remember the part number right now, but I have it somewhere.
So yours just bolted right in after trimming the panel?
Old Nov 15, 2010 | 11:05 AM
Rick03F250's Avatar
Rick03F250
I really like the looks on all the trucks showing the updated lights, My question is: Do they give you better visability at night?
My '03 lights s**k for night driving. Makes it hard to see the deer coming at you from the fields. Been thinking of different bulbs but the update looks great. Just wondering.
Old Nov 16, 2010 | 11:02 AM
BCHauler's Avatar
BCHauler
Does the grill have to be changed as well or could you just change the headlights with this mod?
Old Nov 16, 2010 | 11:29 AM
scottzj's Avatar
scottzj
Hangin 10 bra
I put my own bolts onto the existing frame and made it adjustable, so I guess you are somewhat correct, the top mount you have to fab or bolt. Heck I have seem some use sheet metal screws and just screw them into place when the light is level.
Old Nov 16, 2010 | 11:41 AM
scottzj's Avatar
scottzj
Hangin 10 bra
Negative, you can do either mod you want without the other, grill or headlights...
Old Nov 16, 2010 | 11:52 AM
BCHauler's Avatar
BCHauler
Thanks. Do the 05-07 headlights give better light than the 01 lights do? I'm really unimpressed by their brightness.
Old Nov 16, 2010 | 12:33 PM
scottzj's Avatar
scottzj
Hangin 10 bra
Well mine do. My 04 King Ranch lights were in great shape but didnt give me near the brightness that these now do. However, I did change the bulbs out with the hyper white type ones.
Old Jan 1, 2011 | 12:40 PM
99StrokeXLT's Avatar
99StrokeXLT
Scott,
Im looking at doing the same conversion you did to my '99 I was just wondering how you went about doing the grille. Did you use the conversion trimmed grille available off the internet or did you trim the stock one yourself? thanks
Old Jan 1, 2011 | 03:21 PM
Mr-Pipeline's Avatar
Mr-Pipeline
Here's a link to my front end conversion including upgraded headlights with relays. https://www.ford-trucks.com/forums/1...rduty-v10.html I didn't document the process because it's been covered hundreds of time. Let me know if you have any questions.
Old Jan 4, 2011 | 07:02 PM
99StrokeXLT
Thanks Mr-Pipeline I looked at the link and it looks great. I was curious because I wanted to just change out the headlights and grille to the newer 05+ style keeping the bumper cover and valance that i have. You're right though it has all been covered many times, i was just looking for the short answer. I just ordered heat/signal tow mirrors so there'll by some tinker time in my future to wire those in. Thanks for the input.
Steve
Old Jan 22, 2011 | 02:59 PM
  #28
WMNY's Avatar
WMNY
I've been stalking this thread for enough time to get inspired and convert my 99 SD to the 07 grille and lights. Thanks Scott for the help through emails, you saved me a lot of pain.
Here's a guide I made to make sure my grinder didn't slip and take off too much of my grille. It is a modified 4" grinder guard from Harbor Freight and I just welded the two brackets to the guard and screwed it onto a block of 2x4 to guide the grinder. Worked like a charm. Cost was $6.00!!!!
Thanks again Scott for your help and encouragement. This is a great forum.
WM
Old Apr 11, 2011 | 02:37 PM
  #29
arusty1's Avatar
arusty1
Reserectin' an old thread, my '03's header panel is cracked up (adjustment tabs broken-looks like a rear ender)
Question, so the '05 header panel changes out with '03 with alterations to the center bar, and then I can mount '05 headlights w/ the proper lamp adapters?
...Rusty
Patrick11
Mar 31, 2017 02:40 AM
Boss_hoss
Oct 27, 2010 10:31 AM
jetdoc
13
Oct 30, 2009 04:11 PM
lifted04xlt
Aug 6, 2009 08:40 PM
