Headlight advice needed
Old Oct 28, 2009 | 08:23 AM
jetdoc's Avatar
jetdoc
Sorry guys...Haven't been on in a while. You know how it is. Livin gets in the way of life! My girls and work have the habit of keeping me extremely busy. But I digress...
Driving home in the rain last night I realize that I cant see "jack". I tried the old headlight polish trick over a year ago but these stock lenses have clouded up with a vengance. Time for a new set. (it sucks getting old) I like the look of the 07 Harley ones. I found them off ebay for 128 bucks. (headlight depot).
2007 FORD F250 F350 F450 HARLEY SUPERDUTY HEADLIGHTS:eBay Motors (item 180272792200 end time Nov-25-09 17:05:47 PST)
At the same time I'm going to install the wiring upgrade kit.
Headlight Conversion Harness
My question.... Are these lenses just "cheap chinese junk" or are they the same as OEM. I dont mind spending the money for something thats going to last.
In addition, if you can recommend a good supplier for these lenses it would be most apprieciated.
On a side note..What happened to Markadeck?
TIA
Duncan
Old Oct 28, 2009 | 08:35 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Duncan,
On the headlights IMHO stay away from the chinese aftermarket, they are cheaper for a reason. Hit up HighOctane and he can tell you all about how his faded and hazed in under a year. I have these if you need them, but I don't want to answer your question just for a sales pitch. But I can tell you I just swapped and am extemely happy to be able to see again. Here is a link, give me a call if you have any questions.
http://www.riffraffdiesel.com/mm5/me..._Code=F731-OEM
And here is a link for our brother Markadeck
https://www.ford-trucks.com/forums/8...be-missed.html
Old Oct 28, 2009 | 09:02 AM
agg_bagg's Avatar
agg_bagg
clay does that plug and play harness. will that make it so the lights will simply plug into our 99-04 trucks. so we don't have to splice and stuff....
and what is the difference between the two
Plug & Play 9007/9008
Plug & Play Relay Harness
Old Oct 28, 2009 | 09:09 AM
Riffraff Diesel
PREMIUM SPONSOR
Yes, it allows you to just plug in to your stock 99-04 harness and then plug the headlamp in. I will have pictures soon of the harnesses, but the top on is just a conversion harness while the lower pulls power directly from the battery and is actuated by a relay.
Old Oct 28, 2009 | 09:12 AM
agg_bagg's Avatar
agg_bagg
is there a specific reason why you would need to pull power from the battery. won't the new lights run off of the power from the old harness.
Old Oct 28, 2009 | 09:19 AM
Riffraff Diesel
PREMIUM SPONSOR
Yes, but it just allows for slightly higher voltage to the bulbs which can give you a little more light. Unfortunately it can also shorten bulb life a little as well. You can also use the Brite Box which has the conversion built in.
Old Oct 28, 2009 | 11:02 AM
wuttrd's Avatar
wuttrd
head light
just got thies from clay with the plug and play simple to instal. before and after much brighter
Old Oct 28, 2009 | 11:29 AM
empiretc's Avatar
empiretc
agreed. stay away from aftermarket stuff. just do it right the first time. it is a lot cheaper now than when I did it.
Get the 05-07 headlights, the upgraded wire harness, and a set of silver star bulbs to go with it. You will not be disappointed!
And there is always the cool factor!
Old Oct 28, 2009 | 01:04 PM
farmb0y's Avatar
farmb0y
Clay, you may be hearing from me soon.
I purchased the cheap chinese ones a few years ago, and they have held up well. But I've got one headlight taking on moisture and turning dark.
Old Oct 28, 2009 | 01:30 PM
jetdoc's Avatar
jetdoc
Originally Posted by Riffraff Performance
Duncan,
Riffraff Diesel: 05' Ford OEM Headlights
Thank for all the input!
You have me sold on those headlights. The more I read about the knock offs the less inclined I am to buy them. Just have to come up with the money.... Need tires as well. Wife's gonna love this!
It saddens me to hear about Mark. It seems every time I come back, someone else has fallen. But the truly amazing thing is the response from all here. I read a post about this (FTE) being a brotherhood earlier today. I'll go out on a limb and say that this 7.3 forum is like none other on the internet, that I've come across anyway. It's a good thing to come "home" to every now and again.
God bless Marks family and friends.
Godspeed another fellow Marine home.
Duncan
Old Oct 29, 2009 | 12:32 PM
farmb0y's Avatar
farmb0y
How easy is it to put in the '05+ headlights? Isn't there some "machining" to get them in, or do they bolt right up?
Old Oct 29, 2009 | 12:39 PM
wuttrd's Avatar
wuttrd
head light assem
this is the link that i used. little cutting couple screws. the top hols fit in some stock holes that are allready there. for those holes i used some expandable plastic rivits w/ bolts.
File Type: pdf
Old Oct 29, 2009 | 11:22 PM
Riffraff Diesel
PREMIUM SPONSOR
It is actually alot easier than you would think.
Old Oct 30, 2009 | 04:11 PM
strokersace's Avatar
strokersace
Duncan I've bought 3 sets of aftermarket headlights/parklights from Headlightdepot on ebay. The first set were smoked, second ones were the 05 harley lights like you're looking at, and the 3rd set are the stock euro style ones that will be here Monday. They are an Eagle Eye brand and have held up great to the elements that I've thrown at them. No fading, discoloration, moisture collection, nothing. And I expect the 3rd set to be just the same.
There are definitely some chincy aftermarket ones out there that I wouldn't touch with a 10' pole. But I HIGHLY RECOMMEND that ebay seller for headlights that are stock replacements. They are about as close to OEM as you can get without getting OEM.
As for the upgraded harness, I ran one identical to the GOS one. Bought it from dfuser and was about the same price. Quality product and would highly recommend it too.
To each is own, but I've had great luck with the upgraded harness and the aftermarket Eagle Eye headlights.
BTW- The only way that Tom "lost my beer" and Layson could tell the difference between my harley 05 headlights and theirs were by looking closely at the lense. Mine says "Eagle Eye" where the factory ones say OEM Ford. That's it.
Blue7.3
Australia Chapter
65
Apr 26, 2017 04:14 AM
1Aauto
Vendor Specials, Discounts, Product Announcements & Group Buys
Apr 21, 2016 04:49 PM
kornfanjoe
Oct 11, 2012 08:47 PM
SSSimon
18
Oct 18, 2010 05:36 AM
loanman
Apr 15, 2010 01:31 PM
