Recommended turbo
Old Apr 21, 2020 | 10:41 PM
fordman67's Avatar
fordman67
Originally Posted by Khan
I plan on going T4 within the next year on my 95 and it seems like I get a different opinion every time I ask the question: "What SXE turbo will fit 175/30 injectors?" I've gotten anything from the 364.5 with .91 AR housing to a 366 with 1.0 housing. (Injectors aren't final either, it's those or 160/0)
Both Carson and Jody from DP recommended the 366, while UDP/Irate/1023 recommended the 364.5. 1023 was the only the recommend the 1.0 housing (My truck is an auto). Carson stated they're currently running a 366/74/1.0 turbo on their shop truck with an auto and 160/0 injectors and love it.
For those that have played around with the AR housings, is there really any reason to run a 1.0 over the .91? Irate has said they run the .91 up to 550hp, and this truck is mainly a daily driver unloaded, but I want to be able to hook up to 10k at most if need be. I don't have anything to pull around, but the general vibe I'm getting is to rock the 364.5/74/.91 turbo.
-Jake
This is really a lot about opinion
there are guys on here with 366sxe towing heavy!
Travis has his daily SD that's 364.5 and he loves towing with it. I dont think you have a bad plan either way.
I personally would go 366. Not that I did tho lol
Old Apr 22, 2020 | 09:47 AM
nateairman's Avatar
nateairman
I think Glenn runs a 366 and 160/0.
I run a 366sxe and 160/0. It runs good and makes boost plenty quick. If you are an auto you could run a bit bigger with out the lag due to how the transmission shifts. With the manual though a little smaller is good to get back into the boost quick after a shift. All my opinion though....
2006powerstroke90
May 10, 2011 06:07 AM
Rocketattack
Apr 6, 2011 10:42 AM
Nitesaber
Jan 22, 2011 06:56 AM
proudtruck
16
Apr 1, 2009 11:51 AM
