needing turbo
Old Mar 29, 2009 | 10:44 PM
proudtruck's Avatar
proudtruck
Unhappy needing turbo
I have a 1999 powerstroke and so far a couple of mechanics say my turbo is going out. I see alot of turbos on ebay for 500.00-900.00 are those good or are they just factory size turbos your input will be helpful in me buying one
Old Mar 29, 2009 | 11:03 PM
triskit16's Avatar
triskit16
Those are most likely just the reg stock turbos. 1500 or so and up and you will be getting into the "upgraded" turbos.
Turbo going out...search ebay for a turbo rebuild kit...like 100 bucks and you can do it yourself...
http://cgi.ebay.com/ebaymotors/FORD-...9817QQtcZphoto
Someone will be along shortly to tell you more. Im by no means a turbo expert!
Old Mar 29, 2009 | 11:16 PM
proudtruck's Avatar
proudtruck
what would you consider a good turbo the htt big bad wulf or the gt38r powermax
Old Mar 29, 2009 | 11:21 PM
Tenn01PSD350's Avatar
Tenn01PSD350
First things first. Make sure your turbo is going out. Of course if you are looking for an excuse, then just go Garrett or rebuild yours. The van turbo is also a very popular option. You can rebuild your own but I suspect this is not the direction you are leaning towards.
Old Mar 29, 2009 | 11:25 PM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
If my turbo was definately going out again. If not out already, Garrett 38r would be the easy way. Remove old and install new. Hopefully you have exhaust, intake and gauges already done.
Old Mar 29, 2009 | 11:30 PM
hucka1a's Avatar
hucka1a
Is your truck an early 99 or late? There is a huge differance in the turbo set ups. There is only 1 drop in replacement for the early 99, IIRC.
Old Mar 29, 2009 | 11:31 PM
PaysonPSD's Avatar
PaysonPSD
proudtruck,
I assume you have a late 99 because you did not say early 99. Makes a huge difference if you replace your turbo.
Edit : You beat me to it Huck
Old Mar 30, 2009 | 12:12 AM
proudtruck's Avatar
proudtruck
my truck is a late 99 and no i don't have an exhaust and gauges need them thou. A bigger performance turbo is good for performance but pulling my mustang to the races 3 times a month won't hurt it. How will a bigger turbo help me
Old Mar 30, 2009 | 08:32 AM
mueckster's Avatar
mueckster
I went with the Garrett 38r. Higher volume of air aids in better combustion efficiency. "Cleaner" boost (less smoke)---meaning more fuel burned. Peak boost dropped slightly, but there is more power due to the better efficiency. I roll a little more smoke upon "rapid" acceleration at lower rpms, but it quickly goes away as the turbo spools up. The 38r really makes a difference after the turbo "lights" and also drops the EGTs substantially. I haven't towed yet, but EGTS have been lower across the board, especially at the peak.
Old Mar 30, 2009 | 09:31 AM
Izzy351's Avatar
Izzy351
This is the exact same experience I had with the Van turbo. **BUT** if you go with a bigger turbo, you will need tuning to make it work. My truck is a complete turd in stock mode with the bigger turbo.
And to back that up, you will need intake, gauges, and exhaust at a minimum.
EDIT: I see you have the Edge Evo. It might be okay with the bigger turbo, but I *highly* suggest some custom tuning (like Tony Wildman or DP tunes). It will make a huge difference...
Old Mar 31, 2009 | 12:53 AM
Motoxman_117's Avatar
Motoxman_117
Smile
I am putting the 1.15 AR Exhaust housing on mine but have stock injectors with a diablo predator for now. I use my beast to tow a 30ft Keystone Raptor TT and wanted this for the lower EGT`s, should I expect it to be a laggy turd now or will it still be better than the stock turbo for towing? Also, wasn`t trying to hijack this thread I just thought it might be good info for him also.
Old Mar 31, 2009 | 07:50 AM
mueckster's Avatar
mueckster
I would say it will be somewhat "laggy" in the lower hp tunes and at low rpm. I had the 1.0 turbine & ATS compr housings, on the stock turbo, before switching to the 38R so I didn't see much of a difference in the response. It actually spools quite well. I went with the "as equipped" 1.0 and a Turbonetics 31165 Hi Flo Exh Outlet to try to get a balance of quick spooling and lower EGTs. This seems to be working out well, so far. I may need the 1.15 after I get "SS sticks", but I will try it with this combo first.
Old Mar 31, 2009 | 10:23 AM
Izzy351's Avatar
Izzy351
Yeah, I'm not sure how laggy the 1.15 will be with the Evo. Mine is fine with Tony's tunes, especially on the Extreme & Race tunes, but they dump a TON of fuel on the low end. The Daily-Driver & Tow tunes are slightly more laggy though. You WILL have a huge drop in EGTs, but I'm betting it will be a bit laggy. My suggestion would be to go ahead and try it out, but be prepared to drop some $$$ on custom tuning if it turns out to be too laggy for you.
Old Mar 31, 2009 | 07:51 PM
proudtruck's Avatar
proudtruck
what do you guys no about the BD power thruster turbo is it any good
Old Mar 31, 2009 | 08:11 PM
jdecker88's Avatar
jdecker88
Jeff7825 has a turbo for sell with a high flow outlet (stock turbo) you might want to PM him on the price just a bit over a 100K on the turbo and it looked to be in great shape.
