Gauge install
Old Mar 22, 2010 | 08:17 AM
crazer42's Avatar
crazer42
Smile Gauge install
My gauges will be here this week!! Just wanted to know how much time I should be expecting to need! And if there are any tips, or tricks to make the install any easier. Thanks
boost
trans
egt
Old Mar 22, 2010 | 08:22 AM
Izzy351's Avatar
Izzy351
Took me a couple hours after work for two days to get 'em in. I put in all the sensors and pulled the wiring one day, and wired & powered the gauges the second.
The only thing that might be tricky is tapping the up-pipe/manifold if you haven't done it. You need to pull out the tap and test fit the adapter once you get to be about half way in with the tap. I put mine in the up-pipe and it was several threads short of going all the way in where the adapter was all the way in with the nut flush on the pipe.
Old Mar 22, 2010 | 08:57 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is something that may help you on the install. LINK
Old Mar 22, 2010 | 09:49 AM
just another truck's Avatar
just another truck
It took me an 1 hour and half.. I went ahead and drilled my Pyro in one day. Then the next day at lunch I installed it..
Old Mar 22, 2010 | 11:22 AM
superduty4x4's Avatar
superduty4x4
I helped my buddy install a set recently in his truck- boost and pyro only. Took us better part of a day, with a few runs to get something we needed, and being extremely meticulous with the install. When I did them in my 99 it was about the same deal.
Old Mar 22, 2010 | 12:37 PM
Izzy351's Avatar
Izzy351
I take it back -- it was three nights after work. Painted the gauge pod to match the interior first...
Old Mar 22, 2010 | 02:38 PM
guitarpicr's Avatar
guitarpicr
My 3 gauge pillar pod install took me about 7 hours total, had the pod painted b4 hand. It's a good 6 pack job,lol
Old Mar 22, 2010 | 09:09 PM
caverjoe's Avatar
caverjoe
So would it be worth $120 to have someone do it for you???? That is the quote I got, but I like to do things myself so I am thinking I will try and save the $120
Old Mar 22, 2010 | 09:38 PM
guitarpicr's Avatar
guitarpicr
Joe- That is a pretty good price for a 3 gauge install, I would think, but I'm like you and wanted to do the install myself & learn how things work along the way. If time is pressing that sounds like a real good deal.
Old Mar 22, 2010 | 09:46 PM
caverjoe's Avatar
caverjoe
Time would be the only reason I would think about having it done. It is my work truck and I need it going everyday. Can you stop and start on the project and still be able to drive it?
Old Mar 23, 2010 | 02:18 AM
big poppa's Avatar
big poppa
Yep, do the gauge install and run all the wires from inside and leave all the outside stuff for the next day. Trans gauge sender is easy, just screws in and the boost tee's in at your map sensor and drilling and tapping your manifold or up pipe is a half hour job. To the original poster, just take your time and read your instructions to a tee first then keep them on hand for reference, not a bad job at all.
Old Mar 23, 2010 | 02:23 AM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Also if you do them yourself the experience helps when they think they nedd to go on the fritz.
Old Mar 23, 2010 | 10:41 AM
binuya's Avatar
binuya
Yep, like others have said, just do it in phases. One morning I drilled, tapped, and installed pyro probe.(Less than an hour). Another morning installed electronic boost fitting in Clays AIH delete plug, ran the wires for that and the pyro probe wire into the cab area.(Less than an hour). Yet another day, I installed dash pod bezel, snapped gauges in, dropped wiring under the dash. And finally on another day, (and this is what took me the longest of all the procedures), was to connect all the wiring. Cumulative hours was probably around 7-8, but I fumbled with the wiring somewhat. Aside from that, it was easier than I had expected overall.
Old Mar 24, 2010 | 06:38 PM
crazer42's Avatar
crazer42
im starting to work now, one question, how do you determine where to put the $ clips that hold the pod pillar to the factory pillar, and how big of holes do you drill to run the wires through?
and a question that doesn't matter yet, but does the orger of the gauges matter? like where you put them in the pod? or is it just what you want
Old Mar 24, 2010 | 09:13 PM
crazer42's Avatar
crazer42
just giving my post a bump
