1978 - 1996 Big Bronco
installing headlight buls
Old Jan 24, 2003 | 06:01 PM
WhëëlMå1's Avatar
WhëëlMå1
Question installing headlight buls
How do I go about changing headlight bulbs? It looks like its a simple twist and pull, but Id like to actually know what Im doing before I start pulling random things out from under my hood. TIA
Rich
Old Jan 24, 2003 | 06:10 PM
DeKuma's Avatar
DeKuma
I am assuming you do not have sealed beams since you said "twist and pull".
You are right, that is all there is to it. Make sure you do not touch the new bulbs (glass part only) with your bare hands though. The oils in your skin will cause them to blow prematurely. Wear latex gloves or use a clean towel/rag to hold the bulb. I often just use a paper towel.
It is a quick and easy operation.
Old Jan 24, 2003 | 06:38 PM
JBronco's Avatar
JBronco
It depends on the year. On my 90, they twist and pull from the back of theheadlight, under the hood. You just unpug the connector. You never need to touch the glass bulb at all.
Old Jan 24, 2003 | 07:42 PM
WhëëlMå1's Avatar
WhëëlMå1
There in.
Thanks
Redmonkeynut
Aug 1, 2021 07:02 PM
Aaron_Jones
Jul 17, 2016 10:27 PM
SCRWDRVR
2004 - 2008 F150
Mar 23, 2016 08:06 PM
80ford100
Feb 11, 2015 09:16 AM
Country_boy_2007
Feb 20, 2014 12:20 AM
