1978 - 1996 Big Bronco
Changing the breaks
Old Jan 24, 2003 | 04:58 PM
dassmoof's Avatar
dassmoof
Changing the breaks
How hard is it? I'm curious. My Bronco needs new brakes really bad and I was considering doing them tomorrow, I figured it wouldn't be too hard to replace the pads and I assume I can get them from any parts store like NAPA.
Thanks
Old Jan 24, 2003 | 05:49 PM
mrwizard's Avatar
mrwizard
Changing the breaks
If you do it yourself, take the rotors and have them turned somewhere. Putting new pads on worn rotors isn't even worth the effort.
Old Jan 24, 2003 | 06:03 PM
DeKuma's Avatar
DeKuma
Changing the breaks
Brakes are a pieve of cake. Just make sure you lay all the parts out in the order they go back in to avoid confusion. Should not take more than an hour or so. At least for me it takes that.
Hardest part is getting the spring out/in of place and waiting for the rotors to be turned.
Good luck. Pick up a manual if you do not already have one. It will show you the parts assembled for reference.
Old Jan 24, 2003 | 08:50 PM
craterjoe's Avatar
craterjoe
Lightbulb Changing the breaks
just be sure you only take apart one side at a time so you can reference the other wheel if you get confused as to how it all goes back together....
Old Jan 24, 2003 | 08:54 PM
AlM's Avatar
AlM
Changing the breaks
yo Dass,
I forget what yr you have; so here is an article for a 96:
http://www.autozone.com/servlet/UiBr...3d800d2d77.jsp
look in the index for more info on other years and other parts' info such as rotors, etc.
droffan
Jun 19, 2013 12:30 PM
RickWA
New Member Introductions
Oct 27, 2008 05:44 PM
jkpenny376
Nov 15, 2007 03:13 PM
ellsdemon
Dec 10, 2006 03:16 PM
FTE Ken
Site Announcements
Jul 22, 2005 07:29 AM
