Where Is Headlight Relay?
Old Jul 16, 2016 | 01:29 PM
Aaron_Jones's Avatar
Aaron_Jones
I found that both my headlights was out. I went and replaced one of the lamps and found that it still did not work. I started troubleshooting and it led me to the headlight relay. Does anyone know where to find it?
*When I turn Headlight switch on = No Headlights
*When I turn the switch to auto = No Headlights
*When I turn the switch to headlights and hit the function switch to turn on brights = No Brights either
*If I pull back on the function switch to momentary = Brights come on until I release the function switch
I have 13v on Red/Yellow wire when I switch to headlights, but I do not have any voltage at the Headlamp wires.
Originally Posted by mecdac
Headlight System with DRL '02
Old Jul 16, 2016 | 02:26 PM
mecdac's Avatar
mecdac
Try here: Search Wiring Diagrams if the hard copy is not conclusive.
Old Jul 16, 2016 | 06:26 PM
Aaron_Jones
How do I know which one of these two goes to my truck. I'm having a little trouble.
Headlight PDF files
Old Jul 16, 2016 | 07:02 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I'm a little confused here, is the relay not in the underhood power distribution box ?
Old Jul 16, 2016 | 07:28 PM
Pele's Avatar
Pele
Is your Excursion originally from Canada or anywhere Daytime Running Lights are standard?
Do you have the automatic headlight system that turns on the headlights when it gets dark without you touching the switch?
If not, then you don't have a headlight relay.
EDIT: Disregard, you have the automatic system. Looking at the diagrams and I'll let you know where to look.
The relay appears to be internal to the Headlight switch or in the vehicle security module. (Depending on which diagram above you look at.)
Check a Red w/ Black stripe wire coming from the multi-function switch (Turn Signals, High Beam, etc.)
Also check for presence of power at the two headlight fuses in the under-hood fuse box.
Old Jul 16, 2016 | 08:32 PM
Watcher58's Avatar
Watcher58
Daytime running light relay is in auxillary relay box 2 labeled c1171 and c1172. Don't know which one is box 2. My online manual lists numerous pages for troubleshooting-rather mind boggling. You might want to try a dealer if you can't find it easily.
Old Jul 17, 2016 | 10:20 PM
Aaron_Jones
I don't have an under the hood distribution panel that I can see:
Old Jul 17, 2016 | 10:27 PM
Aaron_Jones
Ok, so I got the time finally to try and troubleshoot a little bit further. My problem is in this module (I think it is the multi function switch):
I can giggle it just right and the head lights come on. Any one anybody know what the actual name is and/or part number?
EDIT: Ok, it is a multi function switch as I found it on ebay and a couple of other places.
Sortofa65
Jul 10, 2018 09:08 AM
fishbeard
1978 - 1996 Big Bronco
Jan 30, 2017 07:40 PM
iamzachearmeroar
28
Aug 13, 2007 04:04 PM
rankhankyellow
Electrical Systems/Wiring
Feb 23, 2007 06:41 PM
madriding1
Apr 26, 2005 03:06 PM
